need help before i throw it away lifter issue
silver1983gt5.0
116
sturbridge,massachussets
Visit site
ok so simple and to the point. noticed a tapping, brought the car home. i have been having issues
with my pushrods, but have now found out why i had these issues they say the car over heated and
weakend the tips. ok ill buy that, makes sense. so i pulled the valve covers took off the rocker arms
and pushrods are all fine. Finally. Took off intake to check lifters and found one of them has a flat
spot on it and im not talking about a little one i mean if i took the wheel off and set it on a table, its
flat enough that it would look like the wheel is in the table. what would cause this? I had valve
springs in the afr 165 heads adjusted for max power to my e cam, wondering if they screwed up and i
have to much spring pressure?
Also to be noted the engine has maybe 1500 miles on it everything inside is brand new. the rest
of the lifters aside from 2 of them are worn on the edges what causes this? Any help would be
greatly appreciated im at wits end with this car. thank you
  • Sponsors(?)
Celeb
SuperMod
Super Mod
Sep 8, 2002
734
12
49
Here and there
It's possible you might have a worn cam lobe.
Either that, or something (debris perhaps) was keeping the roller on the lifter from spinning as it rides the cam.
Celeb
SuperMod
Super Mod
Sep 8, 2002
734
12
49
Here and there
I would pull the cam and inspect if for any damage to be on the safe side. Especially since there was a lifter riding it that had a roller that wasn't turning and flat.
lancec2c30
570
Washington
Yeah, if the lifter was worn that bad then there is likely some damage to that cam lobe.
What do you mean the lifters are worn on the edges? The sides of them that are in the bores on the block?
silver1983gt5.0
116
Visit site
when i say the side i mean the edge of the roller part kind of mushroomed. i talked to a person and he said he thinks it could be not enough spring pressure causing slap between the cam and lifter and wearing the tooling metal? i honestly have no clue where to start this freaking motor has 300 miles on it
dgollem
163
56
Waldorf MD
I know its a pain but you should pull the cam and inspect it. Right now you don't really know what caused the lifter to fail but its a 50/50 bet it also damaged the cam lobe. Since you have it down and the lifters already out its not that much more work to pull the cam. You'll hate yourself if you don't check it. Good Luck!
Thread starter Similar threads Forum Replies Date
njmaier Need some help with my car dying...haven't seen this before Fox 5.0 Mustang Tech 9
F Need help quick before it's too late... Fox 5.0 Mustang Tech 2
0 Installing 4.10 Gears!!! Help Needed before starting 2005 - 2009 Specific Tech 4
R Need help ASAP before i burn this car... Fox 5.0 Mustang Tech 21
pwcracer Need some help with broken bolt before I snap Fox 5.0 Mustang Tech 4
M need some help before i buy SVT Tech Forum 0
N computer help need help before i kill Fox 5.0 Mustang Tech 4
R need help before dream cruise please!! long!! 1994 - 1995 Specific Tech 3
J Need help before shop closes Fox 5.0 Mustang Tech 2
S Please I Need Help With My Windows, Before It Rains... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
R need help with my Grand AM before I get screwed out of $1400 Fox 5.0 Mustang Tech 15
R need helpful tech help Fox 5.0 Mustang Tech 0
F Help needed 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
D Need sct x4 users help please. Digital Self-tuning Forum 0
E I need help with my AC system 1996 - 2004 SN95 Mustang -General/Talk- 5
G Engine Need help with cooling system issue Fox 5.0 Mustang Tech 12
N Need Help w Heater Blower Failure 1994 - 1995 Specific Tech 13
Jetzv8 2014 Mustang radio not working. NEED HELP Mustang Sound & Shine All 0
A Suspension Fox steering rack leaking need help Fox 5.0 Mustang Tech 1
S PWM Fan controller - Need help/clarity on a purchase 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 32
F I need help Fox 5.0 Mustang Tech 1
lamrith New MSPnP2 in 94 Mustang, need help getting stable idle once warmed up. Digital Self-tuning Forum 1
W 347 Header Size and exhaust Diameter 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 50
Z I need help with pistons 1996 - 2004 SN95 Mustang -General/Talk- 1
trlps_ Need help, car wont rev up or drive 1996 - 2004 SN95 Mustang -General/Talk- 2
T Electrical Need help with A/C clutch cycling connector Fox 5.0 Mustang Tech 2
bmgstang Need help with tune high idle Digital Self-tuning Forum 7
S Engine Need help: heater hose routing for 92 2.3 liter 2.3L (N/A & Turbo) Tech 4
T First fox... she needs help. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 42
C Engine Help diagnosing a whine at low gas pedal pressures - 1998gt SN95 4.6L Mustang Tech 2
Kylor Need help pricing 2000 Roush Stage 2 What is it Worth?!?!? 12
0 Need Help Transmission Swap 2005 - 2009 Specific Tech 1
Cheapskate207 Brakes Need help with Brake ID Fox 5.0 Mustang Tech 12
Wayne Waldrep Engine Trouble with the old pile...I mean car. Need some help. Fox 5.0 Mustang Tech 7
YadiStang Need help with my 1969 oil dipstick 1965 - 1973 Classic Mustangs -General/Talk- 8
D 1995 mustang gt 5.0 Need help please! 1994 - 1995 Specific Tech 8
M Need help tuning megasquirt with kenne bell supercharger Digital Self-tuning Forum 9
D Fox Need help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
1 Engine NEED HELP PLEASE!! Fox 5.0 Mustang Tech 4
atey950 89 5.0, Trick flow stage 1 h/c/i, Megasquirt pnp novice needs help Digital Self-tuning Forum 4
Silver Bullitt Desperately need electrical help! 2005 - 2014 Specific V6 Tech 10
Jetzv8 2015 mustang led license plate wiring help needed 2015+ (S550) Mustang -General/Talk 0
wbrockstar Help Needed To Identify Wiring Component On Hanger At Fuel Pump 1994 - 1995 Specific Tech 0
M Engine Need help on belt with V3 Fox 5.0 Mustang Tech 4
O Need help..ASAP! 1996 - 2004 SN95 Mustang -General/Talk- 2
ShadowBlueGT Electrical OEM stereo reinstall wiring help needed! Fox 5.0 Mustang Tech 2
ChuckFoxLx Engine Need help and tips Fox 5.0 Mustang Tech 9
L I'm New, Need help. please. SN95 V6 Mustang Tech 1
A Engine Need Help Finding a Part Classic Mustang Specific Tech 1
T Need Help With Wiring Fox 5.0 Mustang Tech 2
