- May 30, 2009
- 5
- 0
- 0
My 5.0 will barely run or will die when i plug in sprout after setting timing , it runs and starts fine without it plugged in,but will not start, or if it does , barely will run or die, im wondering if i have a wiring issue or if this could be caused by a bad o2 sensor, both wires on the sprout have the same voltage, around 5 volts, i have put in new dist, coil, actually 2 different new ones, cause i was thinkn i may have gotten a bad one, so i have elimated the problem bein a dist or coil, i have took off the ground wires by the computer and battery for the harness, and sanded the metal, thinkn this would fix my problem,because of a bad ground, i have the timing set at 10 degrees, i just cant figure out why the car will barely run or die when i plug in the sprout after settin the timing, if anyone has any idea with my problem please help
