I have three Fords and I know and understand how to program the key fobs. No biggy there, my problem is with the granddaughters 2000 coupe. Her fob quit working so she switched to another fob and it worked for awhile but has stopped working. I followed the programming instructions and the locks did not activate like they usually do. Nothing at all. My first inclination is to look for a blown fuse in the circuit. It is fuse #19 and all the other things connected to that fuse work, I didn't have time to put the meter to it but assume it is good.
I will not have the car here to test until Friday, but If the fuse is good, where do I go next. I will need to find the module and pull the connector and clean it, reinstall the cable and test again. I have read that the module is located in the trunk on the drivers side on the support for the trunk hinge. Is this accurate?
Due to the outrageous cost of the modules, I don't want to just go buy a new one. I would, however, like to know the location of the module and the part number so I can find a source for another module if needed. Any help will be truly appreciated.
