need to put a windshield in, help please
all1knew
61
Macomb, IL - 61455
Hello all,
So I bought the 3M 8609 Window-Weld caulk, and the 3M 08610 Window Weld Ribbon Sealer but I don't think I am going to use it. Can anybody tell me what I need to put a new windshield in my 92' coupe. Do they sell the original weatherstripping/seal for these?
Please let me know either way. Thank you.
William Kramer
  • Sponsors(?)
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
and leave as much of the old ribbon on the car, then attach the new ribbon to the new windshield, also helps if you heat it with a blow drier or something first to make sure all the air pockets are out
1987LXragtop
837
Just outside Philly PA
when I did mine last year I completely cleaned the windshield frame and used 3M windshield adhesive from Napa. Ribbon is the only way to go dont use black rtv ala Pepboys because its junk. Make sure the ribbon is not stretched out and that its evenly layed out.
Shaolin Crane
Banned
Oct 6, 2008
2,627
Kommiefornia
Unfortunatley i had to do mine twice, first time i completely removed the ribbon and it leaked, second time around i left the old ribbon and finally had a good seal
njoliver
259
Columbus OH
I use some stuff at work I put around 3 windshield in a week. I primer the glass and the body wiith a special primer. then I use a caulk gun. I dont think I am suppose to say any brand names...These are brand new cars I do this on and the windows always come out perfect and if you by chance get caulk where you didnt want it you can wipe is off with alcohol. I build these cars for testing purposes
njoliver
259
Columbus OH
dude say the brand. if you have something that works everytime then by all means feel free to state such.
I dont know off the top of my head if you look on here monday night I will post it and the type of primer I use. I use a electronic caulk gone so I can lay a nice perfect bead. but if you just have a hand caulk gone it should work just as good. the key to laying it on is keep one bead the whole time when you have to lift the gun up (have to switch the tubes) this is where you can get air bubbles and just take a peice of card board and press down where the seperation is then pull up and this will pull the air out. the vehicle I put glass in are prototype vehicles so I need to check fitting before I put the glass in. I would recommend this to avoid having to move the window around once you do the initial set. I measure the window on the top and bottom of the sides and check the driver and passenger side and make sure you are getting the same measurement on each side. so now you have the window set where you want it. put two peices of tape on the top of the body to the glass on each side of car. draw a line down it, then cut the paper between body and glass. now when you go to set it you know exactly where to put it and have it in the first shot...never lift the glass of and try to reset it. this can cause a **** load of air in the urethane. if you need any other info on setting glass let me know
Thread starter Similar threads Forum Replies Date
M Need help putting big valves in 65 289 heads Classic Mustang Specific Tech 0
L Putting together a 408 stroker for a 94-95 sn95 car. Need some input. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
T I Need Help Putting Tragically Modded Car Back Together 1996 - 2004 SN95 Mustang -General/Talk- 5
L Need Help Deciding Type Of Cam To Put In 65 Stang 1965 - 1973 Classic Mustangs -General/Talk- 6
S New Engine Put In 2000 Mustang Gt, Need Help! SN95 4.6L Mustang Tech 8
boostfrk Engine Need Some Help Putting Smog System Back On Fox 5.0 Mustang Tech 5
mike arntson Putting New Car Together And Need Some Advice. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 11
B Need some quick tips on putting in drivers side window... Fox 5.0 Mustang Tech 14
from6to8 Need And Alignment With Putting On Front Lca's? 1994 - 1995 Specific Tech 17
D Need Some Help Putting Together My 50 Fox 5.0 Mustang Tech 1
2 Putting dash back in , need wiring help 1994 - 1995 Specific Tech 7
C Low RPM's when putting the car into gear- Need advice !? please SN95 4.6L Mustang Tech 8
S Need help putting rockers in 331 Fox 5.0 Mustang Tech 1
nick6690 I put my car in a ditch...need paint ideas 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 50
G Frustration! What do I need to put a GT-style grille on a V6? 2005 - 2014 Specific V6 Tech 6
Mustang5L5 Putting A/C back in my 5.0 - what do i need to do it right for 134a? Fox 5.0 Mustang Tech 6
kalvick I need to put my rear seat back in, im missing pieces SN95 4.6L Mustang Tech 1
8 need help putting starter solenoid back on 1985 5.0 after having it off for 2 years Fox 5.0 Mustang Tech 3
fawcett Putting the Stang back on the Streets-Need help finding parts 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
D Whats the minimum needed to put the hurting on a new edge 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 26
Blown331LX Putting 18"s on my 1990 GT, need fitment advice..... Fox 5.0 Mustang Tech 0
J HELP need to find the least expensive way to put AC in a 68 Mustang Classic Mustang Specific Tech 5
dz187 Putting on new power steering rack/pump, what size hoses do I need? Fox 5.0 Mustang Tech 1
Killa what additives I need to put on my rear diff ? SN95 4.6L Mustang Tech 7
dastang2 putting nitrous on stock 2000 need tune or not SN95 4.6L Mustang Tech 16
Killercanary I put the hardtop on today, need some opinions on paint color choices DUW 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 42
U What do I need to put A/C in my car? 1994 - 1995 Specific Tech 1
T New 4v DOHC engine. Need help putting it in! Please help SN95 4.6L Mustang Tech 2
Hawk5252 Putting on CAI - need some advice 2005 - 2009 Specific Tech 3
J Whats needed to put Cobra brakes and rotors on front of 93 GT ? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
95CobraStang Putting 5.0 into a classic- need help weighing in on choices...thx 1994 - 1995 Specific Tech 3
B what needs changed to put explorer motor in 95 stang? Fox 5.0 Mustang Tech 2
fawcett Stupid: Went to put brakes back on, need help asap! 1994 - 1995 Specific Tech 5
9 88 speed dens. what will we need to do to put 460 1.7 rockers on. Fox 5.0 Mustang Tech 5
0 Need To Fing Torq Specs To Put 5.1 Stroker Together!!! SN95 4.6L Mustang Tech 9
tehnick This car needs to be put out of it's misery Regional Forums and Event Information 6
KStrike155 Going to put in fuel pressure gauge with my KB... need a little help. SN95 4.6L Mustang Tech 4
kramer03gt Putting Car away for a year to do overhaul and need some opinions SN95 4.6L Mustang Tech 15
R if i put on a blower, will the stock tranny need to be replaced soon? Fox 5.0 Mustang Tech 7
Foxfan88 what need to be done put bigger valves into stock e7s?? Fox 5.0 Mustang Tech 19
mricci Whats needed to put aod into 95 GT 1994 - 1995 Specific Tech 4
jb1dsl What all is needed to put performer r.p.m. heads on a 289 Classic Mustang Specific Tech 33
M need help just put suspension on and it doesnt look right SN95 4.6L Mustang Tech 11
6 Need help on putting 93 5.0 heads on 289 rocker trouble? Classic Mustang Specific Tech 4
G if i get a 1989- mustang 5.0 what do i need to put my motor in? Fox 5.0 Mustang Tech 2
PeteyAce need help with putting in new gears and rebuilding traklock Fox 5.0 Mustang Tech 10
T Need Stripes Put On Car Classic Mustang Specific Tech 4
Procharger95 Putting my 3550 from my 95 GT into my 87LX. What will I need? Fox 5.0 Mustang Tech 7
BlueOvalStangGT Can I put a T56 from a camaro in my car? Whats needed? 1994 - 1995 Specific Tech 31
stang9gt needed to put came from 351W into 86 roller 5.0? Fox 5.0 Mustang Tech 6
