Never done this on my own...help?
DKVL
113
I dont have any tools, but i dont mind buying them. Is it easy for me to replace the struts and shocks my self?
What do i need as a tool? What are the sizes? What special precautions must I take? This will be the first time i do this and so any detail instructions will be greatly appreciated.
I heard the front end is harder then the back end is it true?
  • Sponsors(?)
Jbauer
506
You do NOT need an impact for the fronts. From my experience, its impossible to use the impact unless you have a special socket. The fronts are stupid easy. Just shove a screw driver in the slot and turn it with a wrench. Have a friend hold it if you want. Then remove the sway bar holding bolts and tilt it away. Remove the little brackets that hold the brake lines. there are 2 brake lines and one bracket for each line..they come off very easily with i think it was a 10 mm socket on a 1/4 ratchet with a long extension. Put a jack under the LCA and raise it just just enough to support it. Then take off the 2 strut bolts (use a breaker bar if you don't have a impact. They're not hard at all to get off unless they are rusted) lower the jack and THATS IT.
the backs are very easy. about 3-7 minutes a side. just take the covers and carpet off the trunk. Take the shock nuts off ( 1 per each side, 2 in total duh) raise the car, support the diff. with a jack just enough to support it's on weight. take the bottom bolt for the 2 struts out. The strut literally falls out. re installation is even easier than removal.. just shove the new shock back in there, put the bottom bolt on and tighten the top.
All these links show hard ways to do springs and stuff, i can do the whole suspension including springs and shocks/struts in no time. Just gotta ignore all the stupid stuff on all the popular sites.. i've seen sites that want you to take the rear sway bar off, etc. etc. just stuff that isnt neccessary at all.
Rusty67
3,749
36
109
Seattle area, WA
Sway bar and brake lines ? Why the hell do you need to disconnect those ?
Also, not all aftermarket struts have a slot in the top of them like the stock ones, especially adjustable ones.
Last time I did fronts it took me 45 minutes to do the hole job, both sides including taking off and puting the wheels back on. Using an impact makes this job FAST.
Jbauer
506
well your car may be diffrent, but on my car, the brake line is attatched inside the wheel well with a bracket and its been like that on every mustang i've ever seen from 99-04, id ont know about earlier models but something tells me its the same. the bracket is held in with a bolt. You must remove that bolt and loosen the bracket or you will tear that brake line into a million pieces and you will be in a world of crap.
The sway bar LINK must be loosend and the bushing pulled out. I couldnt get the LCA low enough to remove the strut without removing the nut for the sway bar link. it takes literally 5 seconds to remove that nut.. OP it looks like this link over here, you need to remove that nut the guy on that link has on his hand.
http://www.jrfarrar.com/jeep/xj/roughcountry/brokenswaybarlink.jpg
As far not all aftermarket struts not having the slot on top, i didn't think about that. All the ones i've seen always have a slot on top, including, to my knowledge all the performance ones that are sold. I tried to impact mine, but it just spun and spun for minutes..i ended up having to do it the old fashion way.
Rusty67
3,749
36
109
Seattle area, WA
I have never needed to take the sway bar end link off. Not when I did it on my dad's Bullitt and not when I did it on my old daily driver even after I lowered it.
As far as unbolting the breakline, its a safety precaution for sure but you could also just pop the calipers off and stuff them to the side on the k-member. I don't bother, I just do it with everything in place. As long as you are careful with the spindle, the brake hose wont break. Just gota make sure the spindle is supported properly.
Jbauer
506
The sway bar wouldn't let the LCA drop down far enough with the end link bolt installed in my car and i've done springs/shocks over 3 or so times (cutting, etc. trying to get my stance flawless) i've never been able to let the LCA go down far enough with out stretching the brake line, and i'd rather take a 10mm bolt off the well instead of removing a caliper.
Anywayz, every car is a little diffrent i guess, but its better to play it safe then sorry. i hate it when things go wrong
Rusty67
3,749
36
109
Seattle area, WA
If you are doing the springs with the struts then you are absolutely correct, you need to take off the swaybar end link and the brakes to do that.
Thread starter Similar threads Forum Replies Date
MAC'n89Blckstng Well, like they always say, they're never done. Building another motor. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
68stang351 I will never be done with my car. 1965 - 1973 Classic Mustangs -General/Talk- 89
bjl95mustang My engine is never going to get done. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
stephen4785 Im never gonna get anything done to my car!!!! Classic Mustang Specific Tech 2
snoopy98 how do you powershift????i never done it?? SN95 4.6L Mustang Tech 24
JCBeaver JCBeaver's 1993 GT Coyote Swap "The Never-Ending Project" 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 182
K Fox wow, never really thought this would be a issue 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
C Never been a Mustang guy till now.... The Welcome Wagon 3
Neuron NEVER MIND 1996 - 2004 SN95 Mustang -General/Talk- 1
1fast03pony Expired Wilwood Brakes - Brand New Never Installed - Fits '99-'04 Gt Wheels Tires Brakes 0
knr1313 Engine 92 5.0 Never Seen A Rev Problem Like This Before Have You ????? With Video Fox 5.0 Mustang Tech 9
R Expired Scott Drake Aluminum Radiator Brand New In Box Never Opened Huntington Beach Engine and Power Adder 2
B Expired Dart 427 Afr 220 All New Never Fired Engine and Power Adder 2
G Expired 3v Thumpr Cams New In Box Never Used (old) And Bbk Intake Engine and Power Adder 3
C Expired 94-98 Left Rear Brake Caliper - A1 Cardone - Never Installed Wheels Tires Brakes 0
95CobraStang Expired (never Used!) Tcp Power Steering (rack & Pinion) & Flaming River Adj Steering Column For '67-'68 Drivetrain Parts 0
JasinC19 Expired 19lb Mustang 5.0 Fox Body Fuel Injectors - Never Used! Engine and Power Adder 1
more4u2c Engine Help With Never Ending Hessitation/bad Idle Problem I Cant Figure Out... Fox 5.0 Mustang Tech 36
Black1987Stang Expired Fs Never Used 87-93 Quicktime Turbo Kit W/ Upgraded Turbo Engine and Power Adder 0
F SOLD 1ea 15x10 Unilug Race Star, New Never Had A Tire Installed Wheels Tires Brakes 0
mikestang63 The Mustangs That Never Were..... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
mikestang63 Why My Kid Will Never Drive My Mustang 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
Smitty15us Expired Bbk Long Tube Headers New Never Used.... Exhaust Parts 2
T Member Since...2006 Never Introduced Myself The Welcome Wagon 5
95CobraStang Expired (save $2000!) 1967 Coupe Maier Racing E-body Kit (never Used) Interior Exterior Parts 0
95CobraStang Expired Never Used Kenne Bell Blowzilla Supercharger W/ Flowzilla Inlet Engine and Power Adder 5
95CobraStang SOLD Procar Elite Seats - Never Used! Interior Exterior Parts 1
S Expired Fox- New Never Installed Blk Dash, Perfect Blk Center Console, And Custom Gauge Cluster Interior Exterior Parts 0
hoodrich racing SOLD Brand New Never Used Ssbc Fox Rear Disk Brake Kit. Wheels Tires Brakes 2
98COBRA281 Never Thought I Would Do This....have Always Been A 5 Speed Guy, But Since I Have A Few Miles On Th 1996 - 2004 SN95 Mustang -General/Talk- 7
P (FS) NOS wet Nitrous System 175 shot never used 250obo PICS Engine and Power Adder 0
TOOLOW91 Build Thread My Never Ending 89 Notch Thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5130
wythors Never seen one of these before. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
M Never Again SN95 4.6L Mustang Tech 9
revhead347 How many of you bought an SN just so you would never have to do drum brakes again? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
95CobraStang Kenne Bell Blowzilla w/ Flowzilla Inlet (never installed) Engine and Power Adder 0
88-378 Never Fails! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
B Holley Blue Fuel Pump. Brand new never used Engine and Power Adder Parts 0
C Well, I never thought I'd be buying a Ford.. The Welcome Wagon 1
J NEW never used---WELD Alumastar 2.0 & Drag Radials Wheels Tires Brakes 1
5.0convert88 2 OE SALEEN RIM'S!! never mounted 18x9 Wheels Tires Brakes 1
B 03 04 cobra front bumper and bezels (EVERYTHING IS BRAND NEW) NEVER USED!!! Interior Exterior Parts 7
BLOWN 5.0 FOX (1) Ford Racing 17" 4 lug silver Cobra R- BRAND NEW NEVER MOUNTED Wheels Tires Brakes 0
GT Trooper 10lb NOS bottle brand new/never used Engine and Power Adder 0
NinjaKiwi84 GM never again The Welcome Wagon 0
hotstang_46 Never Buy KBD Bodykit, Cruizin Concepts 1996 - 2004 SN95 Mustang -General/Talk- 14
9 At least I can't say I have never.... 1996 - 2004 SN95 Mustang -General/Talk- 11
BurninRubb3r My buddy is never allowed to help me with my car again! 1996 - 2004 SN95 Mustang -General/Talk- 9
188slo50 My never ending progress thread 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 36
Venom351R The never ending oil leak...Advice? 1994 - 1995 Specific Tech 28
