As for the kit I like it, it is your typical plate kit like the old fox body one's. I bought all the safety goodies also, better safe than sorry. There is clearance problems and everything lined right up. The only problem was the car ran extremely lean my 1st dyno, I am not sure if it was the plate that was causing it but I added 30# injectors, a focus pump and the new tune. Which should fix the problem.
Otherwise the plate kit is identical to NX older EFI kits with the obvious addition of the plate.
I will keep you posted on friday afternoon with my new results.
