Nuetral safety switch
Mjc06
24401
I have a 94 mustang GT automatic. It won't crank or anything.i think it might be nuetral safety switch. Can someone tell me where it's located on the automatic and how hard is it to change?
General karthief
Mod Dude
Aug 25, 2016
12,379
3,930
193
polk county florida
It appears to be located on the trans at the shift lever. Make sure this is the problem, as far as I know they rarely go bad.
Mjc06
24401
Is there a viseo for this I keep finding one for Manuel but not transmission. We don't believe it's the starter.we have no idea what else it could be. It won't crank or anything
General karthief
Mod Dude
Aug 25, 2016
12,379
3,930
193
polk county florida
Start at the battery, cables tight and clean, check power to solenoid, ignition switch and starter.
Have you tried moving the shift lever with the ignition engaged?
General karthief
Mod Dude
Aug 25, 2016
12,379
3,930
193
polk county florida
Ok, so you have power at the battery, solenoid, ignition switch and starter. What happens to that power when you turn the key to start? Do a voltage drop test on the above components including the nss.
Mjc06
24401
I'm not sure where to locate the nasty. I actually tried a new starter and still nothing.
