O2 sensor wiring
stangman16
623
San Antonio, TX
My O2 sensor harness is toast... found out it was giving me incorrect readings and causing all sorts of pain.
I have the Probst book and my O2 connector does not look the same as the one pictured.
Pardon my horrible paint skills: :)
Here's from the book:
Please help me identify which wire is Hego Signal, PWR Ground, and Key Power. I would think that the black wires are the ground and Key Power is the white wire, but then it doesn't line up with that schematic. I can't go off my O2 harness either.
The O2 sensor is a bosch sensor
  • Sponsors(?)
jrichker
StangNet's favorite TOOL
SN Certified Technician
Mar 10, 2000
27,282
2,631
234
74
Dublin GA
lowendmac.com
The 5.0 Mustangs onlty use 3 wires for the O2 sensors. One 12 volt power to the heater, one signal out to the computer, one ground that is shared between the heater and computer signal.
Diagrams courtesy of Tmoss & Stang&2birds
See the following website for some help from Tmoss (diagram designer) & Stang&2Birds
(website host) for help on 86-95 5.0 Mustang wiring Mustang FAQ - Engine Information Everyone should bookmark this site.
Ignition switch wiring
Complete computer, actuator & sensor wiring diagram for 88-91 5.0 Mass Air Mustangs
Complete computer, actuator & sensor wiring diagram for 91-93 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/91-93_5.0_EEC_Wiring_Diagram.gif
Complete computer, actuator & sensor wiring diagram for 94-95 5.0 Mass Air Mustangs
http://www.veryuseful.com/mustang/tech/engine/images/94-95_5.0_EEC_Wiring_Diagram.gif
Vacuum diagram 89-93 Mustangs
HVAC vacuum diagram
TFI module differences & pinout
Fuse box layout
stangman16
623
San Antonio, TX
Right. Got that, but I need to identify which wire is which on the sensor. The connector on the sensor is different from that which the book shows and from TMoss' diagram shows, I just don't want to take the chance of hooking it up completely wrong and damaging the sensor.
When I ordered the O2 harness, though used, it was stated for 89-93 mustang. Of coarse I now find out it was junk and the connectors are different. When I bought my O2's it was for a '92 mustang 5.0 LX, and it plugged right into that O2 harness. But I cannot find out what each wire is.
I plan on running PIN 43 straight to the sensor and pin 29 to the sensor from under dash where my computer is. (if not just for testing only) I can run a power ground from back of the engine bolt, and I assume the white wire on my O2 sensor is supposed to be hot while in "run" position.
Is the white wire indeed the power, and both black wires are ground? Does it matter which black wire goes to the computer and which one goes to the engine block?
