Overheating problem help
lxhatch91
60
quebec
Hi guy , i have a problem with my fox.
When i go for a ride the temperature go up easy like 210 in 10 min and stay a 210 even on normal ride. The outside temp is 15 degree here , i check every things , fan is ok( electric fan) , coolant is full , rad is good , thermostat is new , sensor is good ,water pump is good, every thing about the coolant system is ok . I suspect a blowhead gasket but noting go out of my exhaust . I dont no wath next to check. (my fox is almost stock headers -msd fire- 3.73 gears )
  • Sponsors(?)
lxhatch91
60
quebec
Yes i just change it , i put 160. Because i belive 180 is too hot . I check all my coolant composant part every thing is ok . I dont know why is overheating . When i go for a normal ride the temperature go up and overheat . Oil level is good too
General karthief
Mod Dude
Aug 25, 2016
16,364
5,218
193
polk county florida
210 is not overheating, it is hot but not overheating.
The stock stat is 195, I use a 180 and it still runs 200 in traffic sometimes a little more depending on air temp. After doing research I have found they are designed to run 195-210.
I also test all thermostats before install,
lxhatch91
60
quebec
I feel i lost power at 200 and here now is 15 degrre. So imagine at the summer at 30 degree is gonna be too hot for sure
General karthief
Mod Dude
Aug 25, 2016
16,364
5,218
193
polk county florida
If it feels like your 'losing power' at 200* then you need to investigate that not attempt to make it run cooler, have you checked for codes? There could be codes and no check engine light, if your year has one, some made before 89 didn't have a cel.
took me a second to figure out why you where posting 30*, your across the border so you read Celsius, that is like 86* down here.
LILCBRA
I started this morning by knocking out some studs
1,909
953
154
48
Marietta, Ga
How is your timing? If it is too far one way or the other it could cause overheating issues and seem to drive fine, maybe even be fine while cruising but overheat in traffic.
  • Agree
Reactions: General karthief
mercurycapri
202
washington
Maybe the temp gauge is off. It happened to me I went to harbor freight and bought a cheap infrared laser thermometer for $20. Found out if wasn’t running Hot.
KZGUNS
I can swing up to 11”
Jul 23, 2018
628
259
73
43
chardon, Ohio
you sure the thermostat isnt in backwards? seem dumb but it happens. have you changed water pump? rotation correct?
Wayne Waldrep
Before I post a pic, do you have one of yours?
860
439
83
53
Cuba, AL
In the good ole days when we were all experimenting I also ran a 160* thermostat. Not a good idea. I run a 180 or 195 now. 160 in my opinion doesn't let the car run correctly in daily driving. If it won't stay cool with a 180 then slapping in a 160 may seem like the thing to do but it's not. There's some other problem I assure you. Your car will run a lifetime at 200* and if you think you feel a power loss then something else is going on. I live in Alabama. Heat index is already 100* here. That's all I've got.
1990 5.0 LX
37
21
18
70
Ben Lomond, CA
How do you know it is actually overheating? Get one of those laser temp gauges and check the upper tank of the radiator.
On my '90 when the headlights are on, the temp gauge goes up because there is some sort of voltage leak to the gauge. Meanwhile, the actual radiator temp is fine. So don't get fooled by the gauge.
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
32,856
9,016
224
Massachusetts
Fuel injected cars run most efficiently at 195-205. running colder can actually have harmful effects on the engine. You shouldn't lose any power with coolant at 200f. Might be sensor related once your engine enters closed loop
How are you verifying your true coolant temp? Factory guage is highly inaccurate
Does it run warmer on the highway, or when idling?
30 degrees? Celcuis? Canadian?
ArtscoolGT
SoCal
I had the same problem. System appeares to be good, changed thermostat, pump was good, refilled system with fresh coolant, finally decided to swap out the radiator and purged the system, now that needle never passes the half way mark.
dcm0123
31
Agreed with possible clogged radiator. Had similar issues.
Look for a black substance in the overflow tank. If it is there you likely have hairline fractures in the head or a bad head gasket. This crud will clog up even a new radiator fast.
Does your fan come on? I believe above 200 it should be but not sure. The relays they use to turn the fans on are known to be troublesome.
Does radiator itself feel hot when engine is 200 degrees? If not, you may have a thermostat problem as suggested above or a clogged radiator.
2000xp8
SN Certified Technician
Aug 8, 2003
6,833
1,003
194
NJ
A 160 doesn't leave the coolant in the radiator long enough, especially if it's a stock sized radiator.
What kind of electric fan do you have? How does it come on? Do you have an upgraded alternator?
How do you know the actual temperature? You said sending unit, which leads me to believe you are going by the stock gauge. Put a mechanical full sweep gauge in and you will know the real temp.
While 210 is warmer than I would like, it's far from overheating.
  • Agree
Thread starter Similar threads Forum Replies Date
C Over Heating Problems, Need Help! Fox 5.0 Mustang Tech 4
9 Please Help Overheating Problem The Welcome Wagon 2
GrapeApe318 Crazy Overheating Problem. Need Help 1994 - 1995 Specific Tech 26
M 351w swap overheating problem,please help Fox 5.0 Mustang Tech 3
Stangit50 Fuel Problems! Possible Overheating? Need help/reccomendations! Fox 5.0 Mustang Tech 3
bdazzgt Help with my overheating problem, not the typical problem Fox 5.0 Mustang Tech 18
S 2000 GT Overheating Problem? Any help? SN95 4.6L Mustang Tech 17
F Help!! 96 Cobra Overheating Problems!! SN95 4.6L Mustang Tech 1
G 95 Overheating problem, please help! SN95 V6 Mustang Tech 18
B Please help, overheating problems 1994 - 1995 Specific Tech 10
J strange overheating problem/please help Fox 5.0 Mustang Tech 4
C Overheating Problem: Please Help! Fox 5.0 Mustang Tech 6
E Please help me with my overheating problem Fox 5.0 Mustang Tech 12
latham83 Overheating problem..Weird..help Fox 5.0 Mustang Tech 6
UnderPressureGT Please help.. Major overheating problem Fox 5.0 Mustang Tech 16
latham83 STILL got overheating problems..help me Fox 5.0 Mustang Tech 11
latham83 Overheating problem..Need major help. Fox 5.0 Mustang Tech 29
S Mystery Overheating problem 1994 - 1995 Specific Tech 6
C Vortech 5.0 With Overheating Problem Fox 5.0 Mustang Tech 5
R Fox Coolant Temp And Electric Fan Issues 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
H Engine 94 5.0 Overheated And Caused A Mess Of Problems 1994 - 1995 Specific Tech 3
W 1968 Cougar Over Heating Problem... Suggestions 1965 - 1973 Classic Mustangs -General/Talk- 14
Matt Shaw Overheating Problem 1994 - 1995 Specific Tech 4
COramprat Overheating Problem SN95 4.6L Mustang Tech 4
5.0 Nostalgia Overheating Problem - '97 Cobra SVT Tech Forum 3
elarm1 Overheating Problem? Fox 5.0 Mustang Tech 5
FordRacing302 Overheating problem 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
L Overheating problem Regional Forums and Event Information 0
L Possible Headlight overheating problem? Fox 5.0 Mustang Tech 8
J Overheating problem 1994 - 1995 Specific Tech 7
fast97gt overheating problems no more 1996 - 2004 SN95 Mustang -General/Talk- 1
mike8066 5.0 Overheating problem 1994 - 1995 Specific Tech 30
StreetDreamsGT Curious overheating issue... possibly an electric problem? Fox 5.0 Mustang Tech 3
StreetDreamsGT Overheated my car, now I need to know how to find the problem and what to check over Fox 5.0 Mustang Tech 13
ahhjaws Overheating problem SN95 4.6L Mustang Tech 13
2 Overheating Problems SN95 4.6L Mustang Tech 14
2 2001 Cobra Problem (Overheating) SN95 4.6L Mustang Tech 5
R overheating problem Fox 5.0 Mustang Tech 8
stangboy575 timing and overheating problem Fox 5.0 Mustang Tech 9
S&B Cant seem to get this overheating problem fixed Fox 5.0 Mustang Tech 9
F 96 cobra overheating problem SVT Tech Forum 1
Bad92GT Couple problems, overheating and distributor! 1994 - 1995 Specific Tech 2
Chythar Found my stupid "overheating" problem 1994 - 1995 Specific Tech 6
87ttopstang 95 GT - Overheating Problems 1994 - 1995 Specific Tech 11
M Overheating Problems Fox 5.0 Mustang Tech 3
R Anyone having overheating, gauge, or fan problems, Please Read! Fox 5.0 Mustang Tech 2
R EVERYONE experiencing unknown overheating problems Please Read!! Check Ground Wires! 1994 - 1995 Specific Tech 5
Vipersix Overheating Problems! Fox 5.0 Mustang Tech 7
Strype Overheating Problems Fox 5.0 Mustang Tech 34
RFMustangGT Overheating problem that me sctaching... 1994 - 1995 Specific Tech 2
