R RAYMOND259 Member Nov 14, 2006 56 0 7 Feb 21, 2007 #1 Feb 21, 2007 #1 I bought some Seal Power E-251k 30, the rings gap is .011 on both of them is that normal or not?thanks
vristang 15 Year Member Mar 31, 2005 4,933 108 124 Seattle Feb 21, 2007 #2 Feb 21, 2007 #2 I can't remember, Every time I have purchased rings they have come with a guide sheet for file fitting the gap. I still need to file fit my rings, so I am subscribing. jason
ozanracing New Member Nov 28, 2006 172 0 0 Feb 21, 2007 #3 Feb 21, 2007 #3 Open them up to .016"-.018" N/A Or more if you are running n20/boost. (.020"-.024")
R RAYMOND259 Member Nov 14, 2006 56 0 7 Feb 24, 2007 #4 Feb 24, 2007 #4 I set top one at .016 and how about 2nd rings around .020 maybe.thanks
Rick 91GT Mustang Master Nov 29, 1999 9,692 95 99 PA Feb 24, 2007 #5 Feb 24, 2007 #5 RAYMOND259 said: I set top one at .016 and how about 2nd rings around .020 maybe.thanks Click to expand... That will be fine, and gapping the 2nd ring larger is the new theory as well...it will help keep the top ring sealed and prevent ring flutter. Just make sure they are square and deburred very well... I assume this is a NA combo??
vristang 15 Year Member Mar 31, 2005 4,933 108 124 Seattle Feb 25, 2007 #6 Feb 25, 2007 #6 Just FYI- I gapped my rings today per the sheet that came with them. Suggested was .016-.018 for the top, and .020-.022 for the second. I think I hit under .017 on the top and under .021 for the second on all cyl's. jason
R RAYMOND259 Member Nov 14, 2006 56 0 7 Feb 25, 2007 #7 Feb 25, 2007 #7 What make sure they square in the bore?I been useing rings grinder from summit
