Please Help Overheating Problem
97 stang 4.6
OK I have two problems one mechanical one with wiring.
First off I have a 1997 4.6l 2v sohc with aluminum cross over pipe, the car is over heating. I bought car and drove 29 miles on highway and it only over heated a Lil about 3/4 of the trip I pulled over and let cool down a bit then got back on highway and turned the vent on to hot and never got out of normal temp range the rest of the way home. Next day took a drive maybe 3 miles and it started get higher then normal so let it cool and filled up resivor on top of radiator, I drove it 5 or 6 miles and temp started rising so I got home and coolant was burping out of theresivor cap. The cooliant isn't mixing with oil I checked, and i dont smell cooliant burning out exughst so don't think its a head gasket, not loosing any power, I ve read about air getting trapped in system so wanted second opions. If there is a good way to burp the system I m up for suggestions, I ve heard of filling up the resivor while cold, squeeze top house till bubbles are out, start car let idle and turn heater on fun blast?
2 my driver side break light isn't coming on when pressing break, passenger side is and both come on when headlights are on. I ve changed the bulbs, so wondering if its just bad wiring or what, I m some what mechanically inclined so I can probably handle it with good advice can any one help?
  • Sponsors(?)
TMAN1970
cooling fans coming on? if heat coming out vents good probably not air pocket. could be bad t-stat. turn hazards on and see if it works if so suspect turn signal switch. common cause.
97 stang 4.6
Thanks tman1970 I m to the conclusion its bad tstat. I tried air pocket test and nope and I ll try the hazzards
Thread starter Similar threads Forum Replies Date
starstruck106 Car overheated and now it won't turn over - help PLEASE 1994 - 1995 Specific Tech 51
9 Timming issue, overheating please help Fox 5.0 Mustang Tech 20
Z Please Help With 5.0 Overheating Issue 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
H 2003 Gt Overheating Issues (please Help) 1996 - 2004 SN95 Mustang -General/Talk- 2
Y Coolant Came Out Of Overflow Cap; Car Wont Start 2005 - 2014 Specific V6 Tech 1
blaxican27 Overheating Issue... Please Help! SN95 4.6L Mustang Tech 38
S Engine 2000 Gt Engine Overheating, Help Me Diagnose Please. *video And Pictures* SN95 4.6L Mustang Tech 12
S Please Help! Ac/overheating Issue. SN95 4.6L Mustang Tech 18
M 351w swap overheating problem,please help Fox 5.0 Mustang Tech 3
JymboSlice car overheating at idle and peeing coolant. help please 1996 - 2004 SN95 Mustang -General/Talk- 7
S Car Overheating (Please Help) Fox 5.0 Mustang Tech 34
G 95 Overheating problem, please help! SN95 V6 Mustang Tech 18
B Please help, overheating problems 1994 - 1995 Specific Tech 10
T Need Help on Overheating Please Fox 5.0 Mustang Tech 0
G PLEASE HELP!!!! Overheating still!!!! Fox 5.0 Mustang Tech 12
J strange overheating problem/please help Fox 5.0 Mustang Tech 4
V overheating please help! SN95 4.6L Mustang Tech 11
C Overheating Problem: Please Help! Fox 5.0 Mustang Tech 6
S Wierd Overheating?? Please Help! Fox 5.0 Mustang Tech 9
E Please help me with my overheating problem Fox 5.0 Mustang Tech 12
T OVERHEATING PLEASE HELP 1994 - 1995 Specific Tech 36
UnderPressureGT Please help.. Major overheating problem Fox 5.0 Mustang Tech 16
8 overheating 4.6 anoter update please help! SN95 4.6L Mustang Tech 1
R Help please Digital Self-tuning Forum 0
L Please Help 2013 GT 5.0 The Welcome Wagon 0
M Please help 1989 GT Hatchback.I can not find an L.E.D.smoked 3rd taillight. The Welcome Wagon 4
J Please help '93 mustang The Welcome Wagon 1
9 MegaSquirtPNP 2 problems please help. Digital Self-tuning Forum 12
D 1995 mustang gt 5.0 Need help please! 1994 - 1995 Specific Tech 8
D please help fuel pressure issue 1996 - 2004 SN95 Mustang -General/Talk- 0
B Help please. wiring for alternator upgrade 2010 - 2014 Specific Tech 5
B "Please help" 95 v6 5speed - v8 carb swap The Welcome Wagon 3
A Please help I can't find bushings 2005 - 2014 S-197 Mustang -General/Talk- 4
1 Engine NEED HELP PLEASE!! Fox 5.0 Mustang Tech 4
M Help please new mustang owner 2005 - 2014 S-197 Mustang -General/Talk- 2
G Hey everyone, I'm new here, please help a girl out with some advice! Sell or restore? 1996 - 2004 SN95 Mustang -General/Talk- 56
R Help please. Burns oil, low compression but no broken rings. SN95 4.6L Mustang Tech 1
Lake Martin John VIN help please. 1965 - 1973 Classic Mustangs -General/Talk- 20
D Please help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
L I'm New, Need help. please. SN95 V6 Mustang Tech 1
L Please help 2.3L (N/A & Turbo) Tech 11
S PLEASE HELP 1996 - 2004 SN95 Mustang -General/Talk- 1
J Paint and Body Quarter window weatherstrip help please 1996 - 2004 SN95 Mustang -General/Talk- 0
D Fuel Starts W/ Fluid. Torque App Shows No Fuel Pressure at Rail. Help Please SN95 4.6L Mustang Tech 10
T Please help, a noob needs help with another exhaust question! 2005 - 2014 S-197 Mustang -General/Talk- 5
M Please help need weatherstrip that fastens to interior quarter panel 1965 - 1973 Classic Mustangs -General/Talk- 0
C Just got a 1990 lx notchback. I need help please 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
J "Please Help" The Welcome Wagon 2
4 Please help my PCM is flooding my engine Fox 5.0 Mustang Tech 11
Infoxicated5.0 Foxbody lean. Please help 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 12
