<- Im calling it
OK. because that makes it any less true. looks like i was mistaken though, the car weighs 160lbs more than i thought.
maybe some people should try to learn rather than saying something is impossible simply because they cant do it.
Camshaft Innovations - RED Death
and heres the update...
Provided by: Jay Allen - Project Red Death (NOW)
01. Block
Displacement: 302
CR:
02. Heads
Brand: Ford
Model: GT40
Ported?: valve job and converted to stud mount only
03. Camshaft (If the camshaft is custom, NOT providing this information is understandable, and NOT expected)
Brand: Camshaft Innovations
Grind Number/Model: EXPERIMENTAL
Int./Exh. Duration @.050": 227?/252?
Int./Exh. Lift: .563"/.547" with a 1.60 rocker
Lobe Separation Angle: 114?
Intake Centerline: 112.5?
04. Induction
Carbureted/EFI: EFI
Intake: Holley lower - Hurricane upper
Carb/Injector Size: 24 lbs.
Throttle Body Size: 90mm
05. Tuner: OEM ECM + FMS Extender + Timing Locked @38?
06. Exhaust
Style:
BBK 1 5/8" header
Diameter: 2.5"
Catted: no
"X" or "H": straight
Mufflers:
Flowmaster
07. Power Adder: NO
08. Transmission
Manual/Auto: Manual
Model:
Plate/Clutch:
Converter Stall:
09. Gears
Style: 8.8
Ratio: 4.56
Differential Style:
10. Rear
Suspension Setup;
11. Front
Suspension Setup:
12. Tires: 26 x 10 MT ET
13. Car Weight: 3160 w/Jay
Time Slip:
60ft: 1.47
300ft:
⅛ ET: 7.09
⅛ MPH: 97.7
? ET: 11.19
? MPH: 119.63
Dyno Data:
FWHP:
FWTQ:
RWHP: 305
RWTQ: 317
