Question with the hooptie?
SMOKEDYA
Well-Known Member
Jul 13, 2003
3,605
Tucson AZ
yeah i know it's an import ricer but the thing wouldnt idol at warm up unless you heald steady gas then after doing this for like 5-10 min. it would idol fine. and it would smoke as in over rich so i sprayed some carb cleaner in the carb and left the air cleaner off it, now it idol's sooner and dosent seem to smoke as bad now, plus it seems to get better gas milage? i just did a full tune up a couple of months ago everything all filter's and so forth. the reason i sprayed it is cause i figured the choke is was sticking. but if i put the air cleaner back on it's back to the same ole thing again? any ideas besides of getting a stang for a daily driver? peace
john :p
  • Sponsors(?)
SMOKEDYA
Well-Known Member
Jul 13, 2003
3,605
Tucson AZ
it's a 1987 4dr honda accord lx that does 0-60 in 15 min. and a mind boggling top speed of 80 mph with the 1320 in about 1/2 hr at 50 mph damn just think if i ahd a VTEC :D peace
john :p
Thread starter Similar threads Forum Replies Date
T Questions about power steering delete!! Need help!! 1996 - 2004 SN95 Mustang -General/Talk- 3
MikeR351w EFI to Carb Distributor Shaft length question... Fox 5.0 Mustang Tech 5
B 2011 V6 - Startup Tick Noise - Camshaft Caps Question - TSB 12-1-17 2010 - 2014 Specific Tech 0
Sonicstang0494 Question about calipers. 1996 - 2004 SN95 Mustang -General/Talk- 5
Waz900 Brakes Foxbody SN95 Booster install Question Fox 5.0 Mustang Tech 3
S 2002 v6 ECU Question SN95 V6 Mustang Tech 0
W 289 t5 questions 1965 - 1973 Classic Mustangs -General/Talk- 1
9 Engine HELP - Fuel Line to Fuel Rail Questions Fox 5.0 Mustang Tech 0
DarkFox Interior and Upholstery This might be a weird question... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
A 93 mustang premium sound radio question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
S Fuel Mass air identify question. Fox 5.0 Mustang Tech 12
L Transmission Question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
Hoytster Wiring questions on new MS3X install Digital Self-tuning Forum 2
DarthBubbles 1988 LX 5.0 restoration questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 21
8 Coyote swap questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 37
A Gasket kit questions SN95 4.6L Mustang Tech 0
T MS3 Gold Box (87-93 Mustang) - IAC Valve Mode Question Digital Self-tuning Forum 4
4 1964.5 Coupe tail light question 1965 - 1973 Classic Mustangs -General/Talk- 3
R Passenger side leak issues and cowl questions 1996 - 2004 SN95 Mustang -General/Talk- 1
351crownvic Engine 95 5.0 replacing 93 5.0 questions Fox 5.0 Mustang Tech 8
V Early fox body dual exhaust conversion questions Fox 5.0 Mustang Tech 4
D 1997 Cobra (New Owner Questions) SVT Tech Forum 1
Old Catman EFI and megasquirt questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
o willingham T45 Transmission question 1996 - 2004 SN95 Mustang -General/Talk- 6
A Exhaust Question 2005 - 2014 Specific V6 Tech 9
My92cashtrap Engine Roller rocker question Fox 5.0 Mustang Tech 3
derek2079 I has question about my radiator temps 1965 - 1973 Classic Mustangs -General/Talk- 3
gearhead77 LED question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
M New member, question about custom order times The Welcome Wagon 2
General karthief Fuel Purge canister question 1994 - 1995 Specific Tech 11
Red50Fox 88 Mustang GT 5 lug / disc conversion (almost done!) parking brake question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
Old Catman Questions - Putting a 93 5.0 in a 66 1965 - 1973 Classic Mustangs -General/Talk- 2
R Paint and Body 1991 mustang ssp questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
B Engine Questions regarding a 93 Cobra Vacuum Leak/Intake Manifold Fox 5.0 Mustang Tech 6
M Question for you (Mustang) paint experts out there Mustang Sound & Shine All 3
F hello new person here. with a question The Welcome Wagon 4
Gs87GT Fox Questions on stock suspension rebuild. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
N Bought a unfinished 5.4 dohc into 97 gt project. I)ve got lots of questions. The Welcome Wagon 2
D 1999 cobra blower questions SVT Tech Forum 0
Mystang66 Holley 4180C question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
91GTstroked Engine 3G alternator ground questions. Fox 5.0 Mustang Tech 12
Red50Fox 8.8 Axle Gear Oil and Modifier Question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
M Trans question SN95 4.6L Mustang Tech 2
S 1985 dashpot and kicker questions Fox 5.0 Mustang Tech 10
C 1995 Mustang GT Megasquirt Timing and ignition settings question Digital Self-tuning Forum 36
Mystang66 1977 302 air cleaner assembly question 1974 - 1978 Mustang II Talk & Tech 10
M Questions about a 3.8 swap 1996 - 2004 SN95 Mustang -General/Talk- 0
6 Question about valve covers 1965 - 1973 Classic Mustangs -General/Talk- 6
4 Question about pertronix ignition 1965 - 1973 Classic Mustangs -General/Talk- 0
A Microsquirt setup and first start questions Digital Self-tuning Forum 9
