- Aug 16, 2007
- 2
- 0
- 0
I have searched and found that the probable best choice are the 1.6's although I must ask...
Trying to decide on the 1.6 or the 1.7 rocker arms. My application is a 93' 5.0 block with cast iron 93' GT40 heads. The problem is that I have a trickflow stage 1 cam installed TFS-51402000 and I dont want to cause any problems with a bad choice (or lose any potential power ).
Cam stats listed at http://store.summitracing.com/partdetail.asp?part=TFS-51402000&autoview=sku
I have gathered that I will also need this spring set-up to eliminate valve float. http://store.summitracing.com/partdetail.asp?part=TFS-2500100&view=1&N=700+150
The question is- P-V clearance and V/C clearance. Can I get away with 1.7 rollers? Thanks for any input.
