steveb24
Kilgore Trout said:Try the Kilgore method instead: "If they are stock they need to be replaced."
lol. isnt ur car bone stock?
What are your goals for the car? Suspension is one of those things that you get what you pay for, and maybe people have subjective tastes as to what is acceptable in terms of ride quality.
hate to say it, but many suspension setups for the mustang cater to looks (lowering) and performance so they tend to be tougher than OEM. When you changing the suspension on these cars, it snowballs into needing more and more parts to correct what’s you’ve changed. (Ie. Caster camber plates, bumpsteer kits, adjustable upper arms to correct pinion angke, etc. )
your springs are the cause of your trouble, and I do remember Neuspeed selling mustang springs 20 years ago. The issue is likely the spring rates were too stiff for the struts/shocks causing them to fail. You want to find a spring that doesn’t lower it too much, and has rates that aren’t excessively stiff. Then you want a proper damper to control the spring.
it is possible to make a suspension setup that handles and rides well. My maximum motorsports coil-overs ride better than any conventional spring setup I’ve ever run, but it wasn’t a cheap package.
Shocks, struts and springs play a major role in how the car feels on the road. But, it's also worth looking at your bushings. If they are the OEM rubber bushings, they are most likely worn out. Do you have rubber/poly isolators on your springs? Old bushings, stiff poly bushings and not having isolators will make the suspension feel jarring.
What shocks and struts did you put on the car? Many aftermarket shocks and struts are stiffer than stock. Often, people will compound ride quality issues by using stiff shocks and struts, springs that are too low and too stiff, and bushings that are more suited for performance driving than street driving.
If you don't plan on using the car for autocross or track, there are les expensive ways to improve ride quality than installing coil overs. A good set of adjustable shocks and struts (Koni Yellow Single Adjustable), a progressive rate spring like the Ford Performance B springs. and new rubber suspension bushings will make the car more comfortable for daily driving and cruising.I
I'm not using the car on a track, not even a daily driver. It's in the garage, unless the weather is nice. I replaced the lower control arms, and bushings. When I replaced the control arms and shocks I installed poly isolators, and I put in KYB excel-G shocks. I will look into the Koni shocks, and the ford performance springs too. ThanksShocks, struts and springs play a major role in how the car feels on the road. But, it's also worth looking at your bushings. If they are the OEM rubber bushings, they are most likely worn out. Do you have rubber/poly isolators on your springs? Old bushings, stiff poly bushings and not having isolators will make the suspension feel jarring.
Also, I was thinking of coilovers, just in case I don't like the ride height of the lowering springs.I'm not using the car on a track, not even a daily driver. It's in the garage, unless the weather is nice. I replaced the lower control arms, and bushings. When I replaced the control arms and shocks I installed poly isolators, and I put in KYB excel-G shocks. I will look into the Koni shocks, and the ford performance springs too. Thanks
Lots of good information. I'm pretty sure I'm going with coilovers. I want a soft ride with the ability to control ride height. I don't want to buy lowering springs, and be disappointed with the ride height. I'm prepared to spend around $1200 for the coilovers. I'm just trying to do some research to figure out which ones I will be happy with. It would be nice to get some with caster/camber plates included. I will also probably install a bump steer kit. Thanks for the information.KYB shocks/struts are not known to be great riding. Poly isolators will firm up the ride a bit as well. Those are probably two strikes against you if you are looking to improve ride comfort. So you really need to decide what level of comfort and handling/looks you are looking to get as it's tough to get the best of both worlds without dropping a lot of money into high end suspension parts.
Definitely look into better shocks/struts. the KYB's may not be up to the task of handling the higher spring rates found on many aftermarket springs. I did run the Ford Racing springs for a while and wasn't a fan of them. It rode rough. Then I had Eibach springs and those were worse. I later changed the springs to OEM Bullitt springs (same shocks/struts) and the ride was MUCH better and very comfortable and yet handling didn't seem all that affected. I later switched to maximum motorsports coil-overs (with bilstien struts/shocks) and it was hands-down the best riding setup I've ever done on a Mustang to date. It's just not cheap. Definitely do your research here, but these are my opinions over what I've done to my cars over the last 20 years or so.
If I had to do it all over again and go with a conventional spring setup, I would look into H&R sport springs or the Max Motorsports Road and Track springs and talk to Maximum motorsports about what shock/spring combo would rival a good OEM feel to it.
Given how much I liked how my OEM bullitt springs rode (the only thing I didn't like was the ride height: too high) I would probably lean towards the MM road and track springs, but I would talk to MM tech first.
I had a 2003 GT i bought brand new. These cars actually rode quite well when they were new.
Yep, probably by the time I buy the caster/camber plates if not included, and bump steer kit, you're probably right. Why would I need subframe connectors? I only drive this car in good weather, no track. I drive it fast occasionally of course, but that's about it. It lives in the garage, unless the weather is nice.I think I was closer to $2k for my Maximum Motorsports setup.
I would also recommend subframe connectors as well, if you don't have them
