I did a search on the sticky tech articles thread for things such as how to bleed brakes and change fluid, how to flush and fill power steering fluid and other things of that type nature. I haven't ever done this stuff on my Mustang and I think it is about time, I want to get it running as smoothly as possible. Anyways, I know that I can read up on things such as this is in my Haynes or Chiltons repair manuals, but I was wondering if anybody else on this forum had any routine maintenance tech article links or off-hand info to supply me with. Any help would be appreciated, but if not then I'm sure I can figure it out on my own. Just looking for help. Thanks in advance.
This is my to do list that I have got so far:
- MotorCraft Plugs
- MotorCraft Wires
- PCV Valve
- 02 sensor
- Distributor Cap & Rotor
- Clean Air Filter
- Adjust Timing (Bump)
- Carb Clean down throttle body
- Properly Set Idle (I am having problems with it)
- Change Oil
- Bleed Brakes
- Change Power Steering Fluid
- Grease Wheel Bearings
- Grease Belts
- Check and Properly Set Air in Tires
- Synchromesh in T5
- MotorCraft Plugs
- MotorCraft Wires
- PCV Valve
- 02 sensor
- Clean Air Filter
- Change Oil
- Bleed Brakes
- Grease Belts
- Synchromesh in T5
