Run Problem
If you are still running the 14# injectors, you should prioritize getting a set of 19# injectors in there.
Any pics of the motor setip? I wonder if something will jump out as not being hooked up correctly
Sent from my big ass iPhone 6 using Tapatalk
Yes
Well, looks like the upper intake is not a 5.0 ho intake. When you said it was an 89 HO, what part did you mean was HO?
You'll prob want to change that whole intake manifold to an explorer setup one day as you are leaving some power off the table.
Vent tube on top of throttle body should run to valve cover . However since you have aftermarket covers, might have to just cap it.
Your EGR is connected to straight vacuum. This is wrong and will keep it always open and is prob the cause of your stumble. The EGR is only supposed to open at part throttle and closed at idle. It connects to a series of solenoid that controls this. For now, remove the vac line and cap it. It will generate a code, but will turn off egr function in computer. Car should run better here
Reactions: 1 user
Ho is the long block I got in a 351w swap from guy that was going to put this in a 58 ford pickup I have the long block for the crown vic and I'm starting to wish I just dropped that hole setup in instead of wanting the roller motor I still have all the vacuum lines and switches I wanted to make it look a little simpler without all that stuff but I guess it's going to make more trouble than its worth
Biggest issue I see right now is egr connected straight to manifold and drawing vacuum full time. At least disconnect that and cap it and unplug the egr sensor til you get it plumbed correctly
Some basic theory to clarify how things work is in order…
EGR System theory and testing
Revised 29-Sep-2013 to add code definitions for EGR sensor and EVR regulator.
The EGR shuts off at Wide Open Throttle (WOT), so it has minimal effect on performance. The addition of exhaust gas drops combustion temperature, increases gas mileage and reduces the tendency of the engine to ping. It can also reduce HC emissions by reducing fuel consumption. The primary result of EGR usage is a reduction in NOx emissions. It does this by reducing the amount of air/fuel mixture that gets burned in the combustion process. Less air from the intake system means less air to mx with the fuel, so the computer leans out the fuel delivery calculations to balance things out. This reduces combustion temperature, and the creation of NOx gases. The reduced combustion temp reduces the tendency to ping.
The computer shuts down the EGR system when it detects WOT (Wide Open Throttle), so the effect on full throttle performance is too small to have any measurable negative effects.
The EGR system has a vacuum source (line from the intake manifold) that goes to the EVR, computer operated electronic vacuum regulator. The EVR is located on the back of the passenger side shock strut tower. The computer uses RPM, Load. and some other factors to tell the EVR to pass vacuum to open the EGR valve. The EGR valve and the passages in the heads and intake manifold route exhaust gas to the EGR spacer (throttle body spacer). The EGR sensor tells the computer how far the EGR valve is open. Then computer adjusts the signal sent to the EVR to hold, increase or decrease the vacuum. The computer adds spark advance to compensate for the recirculated gases and the slower rate they burn at.
The resistor packs used to fool the computer into turning off the CEL (Check Engine Light) off are a bad idea. All they really do is mess up the data the computer uses to calculate the correct air/fuel mixture. You can easily create problems that are difficult to pin down and fix.
Troubleshooting:
There should be no vacuum at the EGR valve when at idle. If there is, the EVR (electronic vacuum regulator) mounted on the backside of the passenger side wheelwell is suspect. Check the vacuum line plumbing to make sure the previous owner didn’t cross the vacuum lines.
Diagram courtesy of Tmoss & Stang&2birds. (the diagram says 88 GT, but the EGR part is the same for 86-93 Mustangs)
The EGR sensor is basically a variable resistor, like the volume control on a radio. One end is 5 volt VREF power from the computer (red/orange wire). One end is computer signal ground (black/white), and the middle wire (brown/lt green) is the signal output from the EGR sensor. It is designed to always have some small voltage output from it anytime the ignition switch is the Run position. That way the computer knows the sensor & the wiring is OK. No voltage on computer pin 27 (brown/lt green wire) and the computer thinks the sensor is bad or the wire is broken and sets code 31. The voltage output can range from approximately .6-.85 volt. A defective or missing sensor will set codes 31 (EVP circuit below minimum voltage) or 32 ( EGR voltage below closed limit).
The EVR regulates vacuum to the EGR valve to maintain the correct amount of vacuum. The solenoid coil should measure 20-70 Ohms resistance. The regulator has a vacuum feed on the bottom which draws from the intake manifold. The other vacuum line is regulated vacuum going to the EGR valve. One side of the EVR electrical circuit is +12 volts anytime the ignition switch is in the run position. The other side of the electrical circuit is the ground path and is controlled by the computer. The computer switches the ground on and off to control the regulator solenoid. A defective EVR will set codes 33 (insufficient flow detected), 84 (EGR Vacuum Regulator failure – Broken vacuum lines, no +12 volts, regulator coil open circuit, missing EGR vacuum regulator.)
EGR test procedure courtesy of cjones
To check the EGR valve:
Bring the engine to normal temp.
Connect a vacuum pump to the EGR Valve or see the EGR test jig drawing below. Connnect the test jig or to directly to manifold vacuum.
Do not connect the EGR test jig to the EVR (Electronic Vacuum Regulator).
Apply 5in vacuum to the valve. Using the test jig, use your finger to vary the vacuum
If the engine stumbled or died then EGR Valve and passage(there is a passageway through the heads and intake) are good.
If the engine did NOT stumble or die then either the EGR Valve is bad and/or the passage is blocked.
If the engine stumbled, connect EGR test jig to the hose coming off of the EGR Valve.
Use your finger to cap the open port on the vacuum tee.
Snap throttle to 2500 RPM (remember snap the throttle don't hold it there).
Did the vacuum gauge show about 2-5 in vacuum?
If not the EVR has failed
EGR test jig
To test the computer and wiring to the computer, you can use a test light across the EVR wiring connectors and dump the codes. When you dump the codes, the computer does a self test that toggles every relay/actuator/solenoid on and off. When this happens, the test light will flicker. If the test light remains on the computer or the wiring is suspect.
To check the EVR to computer wiring, disconnect the EVR connector and connect one end of the Ohmmeter to the dark green wire EVR wiring. Remove the passenger side kick panel and use a 10 MM socket to remove the computer connector from the computer. Set the Ohmmeter to high range and connect the other ohmmeter lead to ground. You should see an infinite open circuit indication or a reading greater than 1 Meg Ohm. If you see less than 200 Ohms, the dark green wire has shorted to ground somewhere.
Ok so the egr codes are gone the only two codes is for pushing in the clutch and the ac switch both of witch are not on the car so the only thing I have to do is pick up a set of 19# injectors witch I have a few leads on and clean up the wiring so it looks thank you guys for all your help you were great
ok now where back to running rich and not sure wear to go if any one has a maf setup for sale please let me know I'm guessing pcm harness and maf thanks or if theres a tunner to adjust fuel
How do you know it's running rich? Do you have a wideband hooked up or are you just gauging this from your nose?.. does the car have cats on it if it does not it will always smell.
Reactions: 1 user
Running rough and I took it to the muffler shop to get pipes hooked back up because I put headers on it and they flooded so bad just trying to start it the next morning I had to tow it home
Code 67 really deals with neutral idle strategy, so you really do want to troubleshoot this code. It's often listed as related to the AC being on, but getting a code 67 is a rather big deal as the engine behaves as if it is in gear and under load..even when in neutral. This sometimes causes hanging idle, or too much fuel at idle.
Have you swapped the Speed density computer in? Or are you still running the crown vic ECU? Have you swapped in 19# injectors if you've swapped to the Mustang ECU?
WHat firing order are you running? The 351 firing order, or the 302?
Do you have the MAP sensor hooked up to manifold vacuum?
I believe this might be a combination of some wiring issues, as well as some mismatched parts.
Forgive me if I made a mistake here as I went back a few pages to refresh my memory
Reactions: 1 user
So the engine is a 89 ho 302 roller using the harness and tranny from crown vic pcm is a speed density fuel pump is a intank 89 mustang gt pump I ran new fuel lines and removed the smog pump it now has headers shortys I did install 19# injectors Ive tried different o2s put new engine temp sensor egr valve all in all it runs better but it will fluid it's self if you start it cold and not rev it to clear the fuel it's not driveable at this point cuss it loads up to much and you have to pop it out of gear and rev the crap out of it. so I'm not sure where to go from hear but a few of the members have said my best bet would be to change the map for maf and that should solve the problems
