Screwed Up Installing Alternator; Please Help
Austin00GT
Hi, I'm fairly new to this forum. My battery and alternator recently failed on me so I decided to take it upon myself to purchase and install a new set. It was a fairly easy job and I was done in under 20 minutes. Now, when I bought the new alternator it's pulley had a diameter that was about 1/3 of an inch smaller than the previous one in my car. I didn't put too much thought into it due to the fact that the sales guy assured me it was the factory size. I took it out for a spin to make sure everything was good, and right off the bat I noticed the battery gauge drastically dropping. I thought maybe the alternator just needed a second to get going, so I kept driving. That's when my problems started. I could feel the car starting to die before it started shaking and sputtering pretty bad. I was close enough to home that I wanted to try and make it to my driveway. The car completely died a few times while driving, so I engaged the clutch and threw it in 2nd gear and popped the clutch. I had a lot going on while finishing up the alternator job and stupidly forgot to reconnect the two cables to the alternator. It looked as though the belt was what was smoking, although I'm not entirely sure. Can running the alternator with the belt attached, neither of the two cables though, ruin the new alternator? Can anyone explain what happened? Thanks so much in advance!
Oh and my car is a 2000 Mustang GT.
  • Sponsors(?)
Neuron
Mustang Master
Nov 6, 2016
795
173
83
71
No expert but I would put an new belt on after reconnecting the harness and try it. With a new belt and properly working tensioner you should be OK.
squeak93
2,144
324
164
38
Joplin, Missouri
Take it off and have it tested. I never get a working parts store alt the first time it seems. Odds are you didn't hurt anything as long as it's a good unit.
Also good advice on replacing the belt if you've not recently. Broken belt means no power steering or brakes and that's a lot of fun.
Thread starter Similar threads Forum Replies Date
C Installing rockers on screw in studs Fox 5.0 Mustang Tech 4
8994 Installing Drive Screws on Valve Covers Fox 5.0 Mustang Tech 5
S KC Clutch question, who screwed me?...provider or installer SN95 4.6L Mustang Tech 4
S KC Clutch question, who screwed me?...provider or installer SN95 V6 Mustang Tech 1
R HELP ! Installed lentech vb and now automatic shifting is screwed!! Fox 5.0 Mustang Tech 3
N $600 plus for gear install...am I getting screwed? SVT Tech Forum 23
R Fuel Throttle body idle screw 1994 - 1995 Specific Tech 2
D Help locating bleeder screw on 2006 v6 2005 - 2014 S-197 Mustang -General/Talk- 0
P Engine Am I screwed? Fox 5.0 Mustang Tech 3
N Dakota Digital VHX question 1965 - 1973 Classic Mustangs -General/Talk- 0
WildFire07 Interior and Upholstery LKQ screw up 2005 - 2014 S-197 Mustang -General/Talk- 0
D '96 GT - Need size for Bleeder Valve / Screw 1996 - 2004 SN95 Mustang -General/Talk- 0
D Steering wheel nut hard to screw on 1965 - 1973 Classic Mustangs -General/Talk- 4
billison Interior screw sizes? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
90Hatchback Interior and Upholstery Interior screw size chart??? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
K Fox Well I screwed up again... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
GrandmasterK Lost Engine Nameplate Screws... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
FastDriver Best t-stat housing available on the market today? or any housing w/o the inevitably leaking bleeder screw... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
Nutty 5.o SOLD Various 87-93 hatchback new screws and hardware Interior Exterior Parts 0
94CobraChaos 1994 Cobra Front Bleeder Screws SVT Tech Forum 1
89five.o Fox Rear Speaker Grille Screws (help Appreciated!) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
billison Foxbody Nuts/bolts/screw List - Temp Sticky 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
M SN95 Block Screwed? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
A 05 Gt Interior Paint Screw Up 2005 - 2009 Specific Tech 0
M Engine Throttle Cable Bracket Screw Fox 5.0 Mustang Tech 0
H 2006 Gt 4.6 Throttle Body Screw/nut Size? 2005 - 2009 Specific Tech 0
S Somebody Screwed Up My Foxbody. Help! Fox 5.0 Mustang Tech 2
Project_66 Need Help With This One! 1966 Mustang 1965 - 1973 Classic Mustangs -General/Talk- 4
B Shop Trying To Screw Me During An Alignment? 1965 - 1973 Classic Mustangs -General/Talk- 30
keybrdcowboy1 Help Identify This Screw? Fox 5.0 Mustang Tech 6
amarucci89 2004 Mustang Brake Bleeder Screw Size 1996 - 2004 SN95 Mustang -General/Talk- 3
Bill9000 4.6l (1999) Fuel Rail Screws On New Manifold. SN95 4.6L Mustang Tech 7
Bill88Stang Engine Broken Idle Speed Adjustement Screw Fox 5.0 Mustang Tech 1
G Screws And Hardware 1965 - 1973 Classic Mustangs -General/Talk- 3
newbie1979 Fox All These Screws . Where Do They Go 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
GoldenEagle91 Exhaust Egr Block Off Screws Fox 5.0 Mustang Tech 25
puffdog0 Am I Getting Screwed? 2005 - 2014 Specific V6 Tech 3
SRT Handz Sn95 Kenne Bell 2.1 Twin Screw Supercharger Sounds *video* 1996 - 2004 SN95 Mustang -General/Talk- 5
astronut1885 Expired Ford Racing Motorsport Screw In Oil Filler Cap Chrome M-6766-f302 Engine and Power Adder 0
T Tps Screw Size? Fox 5.0 Mustang Tech 1
rdharper02 Don't Want To Screw It Up.....engine Start-up List Fox 5.0 Mustang Tech 9
B 98 Headlight Adjustment Screw Is Blocked By Plastic? Please Help! SN95 4.6L Mustang Tech 1
Jeremiah Emerson Drilling Screws Into Trunk Of 1997 Coupe To Mount Subs - Help! SN95 V6 Mustang Tech 3
from6to8 Setting Idle: Which Screw On This Tb Is Correct One To Use? 1994 - 1995 Specific Tech 5
ratio411 Go Right Now And Check Your Distributor Cap Adapter Screws! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
SRT Handz Handz 2.1 Kenne Bell Twin Screw Walk-around Video 1996 - 2004 SN95 Mustang -General/Talk- 8
boostfrk Filling Screw Holes In Console Top Fox 5.0 Mustang Tech 1
Mstng93SSP Need Help With A Screw Size (gt 40 Intake) Fox 5.0 Mustang Tech 3
9 Screw In Intake Temp Sensor SN95 4.6L Mustang Tech 3
89LXakaSally Any one know where I can get all the pannel screws for the Inside the Hatchat 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
