I was following the surging idle checklist while trying to set the base idle I noticed that almost no matter what the idle screw was at the base was the same about 750-400. at one point it was at 1300 for a bit after i turned it about 3 times so i started backing off now it will not stay above 600 I read in the list that this is a vacuum leak #1 cause.
Am I reading into it too much or I must tackle that vacuum leak first before trying to set the idle again
