Here is some stuff not really addressed in the TwEECer manual, as downloaded from http://www.tweecer.com/downloads.htm
1. The "Update Only" checkbox has a bug that will randomly corrupt the tune when it is loaded into the tweecer. Always double check that this box is not selected after making modifications, as it seems to be check by default. The checkbox shows at the bottom of each of the tabs.
2. When datalogging make sure that you have created a payload and saved the tune (.ccf file) with the "Data Logging" checkbox selected. If this is not done then CalCon will not show any activity while the engine is running.
3. Do not remove the file "Logfile" from the folder "LogFiles". This file is a format file that is used each time a datalog is created. Without the file in this location, datalogging is not possible.
I hope others can add to this.
Welcome to the Fox 5.0 Tuning discussion.
jason
jason
