Someone please explain this to me
  • Sponsors(?)
speedfreak98r
Banned
Jan 31, 2006
Houston Area
THanks that makes sense, i kinda figured that what about "double clutching" what is that?
From what I understand, it is when you let the clutch pedal out in between gears, when it is in neutral. Say you shift from first to second, you would push the clutch in, pull the stick back into neutral, let the clutch out, then push the clutch back in, ans shift into second.
Only some trucks require this kind of shifting, and it is very slow.
spitfirees20
38
What is "heel toe" driving?
It's when you use the heel of foot to control the breaks and the toe of your foot to control the gas in a manual. It is useful for entering and exiting corners at a faster speed, seeing as you can slow down and match the revs for your next shift at the same time. A very useful skill to have.
Double clutching is used on 18 wheelers and older transmission cars. From what I understand, the way the transmission was made and something to do with the syncros do not allow for sloppy shifts like on modern transmissions. What you do is put in the clutch, put the car in neutral, then release the clutch. Then you give it a little blip of gas to match the revs of the next gear that you will be in, push in the clutch, put it in that gear, and release the clutch. If you are good, it will give you near perfect shifts with minimal clutch wear, but it's unnecessary on most modern transmissions.
Thread starter Similar threads Forum Replies Date
Stumbaugh PTVC question. Someone please try and explain SN95 4.6L Mustang Tech 2
Boostedpimp someone please explain the difference between "draw-thru" and "blow-thru" meters Fox 5.0 Mustang Tech 5
deftsound Someone please explain this to me SN95 4.6L Mustang Tech 14
P Can someone please explain how Ford/SVT just keeps ****ing up? 1996 - 2004 SN95 Mustang -General/Talk- 21
S Can Someone Please Explain A Pushrod Engine. SN95 4.6L Mustang Tech 18
Jekyl Supercharger noob. Someone please explain.. Fox 5.0 Mustang Tech 2
S Can someone please explain Classic Mustang Specific Tech 1
MustangMatt1966 Can someone please explain these specs on my camshaft? Classic Mustang Specific Tech 8
M PLEASE SOMEONE EXPLAIN... Fox 5.0 Mustang Tech 1
M Someone please explain pinion angle adjust. Fox 5.0 Mustang Tech 4
R Can someone PLEASE explain.... Classic Mustang Specific Tech 8
D Someone please explain this!!!1 Fox 5.0 Mustang Tech 5
B Weridest thing, can someone please explain? 1994 - 1995 Specific Tech 19
B Can someone please tell me what security system is installed on my 95 mustang 3.8. VIN: 1FALP4041SF249366 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
L Progress Thread Please help Have no clue what this is can someone help 1996 - 2004 SN95 Mustang -General/Talk- 4
R Electrical Please Help Me Someone SN95 4.6L Mustang Tech 18
modulistic Someone Please Hold My Hand Re: Wide Band O2 Sensor And Gauge Fox 5.0 Mustang Tech 10
DemonHorse89 Need A Little Help Planning My Engine Build From Someone Knowledgeable Please!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 34
S Wheels-Tires Can Someone Please Help Me Out Classic Mustang Specific Tech 2
S Can Someone Help Please With 91 Window Motor Problem Fox 5.0 Mustang Tech 5
White1987GT Bad Fuel Pump? Someone Please Help! SN95 4.6L Mustang Tech 2
M 2 Month And Couldn't Fix My Problem, Can Someone Help Please 2005 - 2009 Specific Tech 7
mob Someone Please Help Me Fix My Car Fox 5.0 Mustang Tech 1
marine_2003 Can someone help me with a price please! 1996 - 2004 SN95 Mustang -General/Talk- 9
strattoc Can someone measure some things for me please? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
topless98gt Could someone run a CarFax please? 1996 - 2004 SN95 Mustang -General/Talk- 5
K CAN SOMEONE HELP ME PLEASE? SVT Tech Forum 3
A FR500 20" W/Stainless lip...Someone please help 2005 - 2014 S-197 Mustang -General/Talk- 2
Q Can someone please measure something for me? Classic Mustang Specific Tech 4
B Please help me ... someone whose smart with tire sizes.. your help will finalize my.. SN95 4.6L Mustang Tech 9
C oil leak getting worse? someone please help 1994 - 1995 Specific Tech 8
gruvee87vertgt Someone please post a pic of a Black Notch on Black Bullets? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
9 can someone carfax my car please 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
0 Can someone PLEASE help decode my rear differential tag? SN95 4.6L Mustang Tech 4
LaserSVT Someone take over the S.O.T.M. poll please. 1996 - 2004 SN95 Mustang -General/Talk- 11
9646gt Can someone please run a carfax? 1996 - 2004 SN95 Mustang -General/Talk- 0
S Can someone please identify this 1994 - 1995 Specific Tech 6
Coast2CoaStang Can someone please help me with a carfax ? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 8
I Can someone please run a CARFAX report for me? 1996 - 2004 SN95 Mustang -General/Talk- 0
I Can someone please run a CARFAX report for me? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
BK_CAULEY Someone please save these cars. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 25
dragin92gt SOMEONE PLEASE HELP Fox 5.0 Mustang Tech 4
BlownStangGT I am going insane, someone please help!!! Weld wheels and cobra brakes! SN95 4.6L Mustang Tech 4
N Can someone run me a carfax please? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
mazen189 can someone please make me a sweet sig. 1996 - 2004 SN95 Mustang -General/Talk- 9
deadly97snake Can someone please run a carfax for me 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
deadly97snake Can someone please run a carfax for me 2005 - 2014 S-197 Mustang -General/Talk- 3
M Someone PLEASE buy this.. ugh! gorgeous. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 24
00GTpony Can SOmeone run a Carfax Please. 1996 - 2004 SN95 Mustang -General/Talk- 1
0 Can someone run me a carfax report please - possible new winter beater??? 1996 - 2004 SN95 Mustang -General/Talk- 1
