Fuel SS Fuel line routing into engine bay?
Bdude93
25
Ferndale, MI
Hello,
I’m doing a ground up resto on a 90LX. It camevto me as a rolling chassis of a 4 cylinder, and was completely stripped down. I’m currently putting the new fuel system in and am laying down classic tube stainless steel fuel lines. They lay out fine on the under carriage, but when it comes around front through k member area, I’m not quite sure how it was routed from the factory. I also have a tubular k member on now so I don’t know how that affects it, if at all.
does anyone have or could snap a couple pictures of how the lines come from the underside and into the engine compartment? It would be most appreciated, as I can find any images online.
thanks in advance
BW
  • Sponsors(?)
Magnet86
54
Hagerstown, MD
Factpry lines on my 86 stayed near the passenger side of the underbody. They seem to thread through the front pass wheel well, then up through a hole and into the engine bay near the canister purge solenoid. The lines connect to the under hood metal lines near the solenoid, and I think at that point they use the pressure fitting, don't recall exactly. Those lines then connect to the fuel rail. But this is a factory set up. I'd say as long as they are out of the way of anything that could damage them you're in good shape.
