- Dec 1, 2004
- 397
- 2
- 18
I'm in the process of fixing my door hinges and I have the interior gutted on my car...so I figured there was no better time than now to install subframe connectors. I was thinking about ordering these for $159 from 5.0 Resto:
Steeda Full length subframe connectors have been improved with a new one-piece reinforced cross brace. Some subframe cross braces have 8 individual gussets which must be carefully positioned and welded on. Still other kits use no reinforcements at all. Steeda cross braces now have reinforcing gussets built-in, for greater strength with less welding.
These true full-length connectors run the entire length of the floor pan for increased chassis rigidity, better handling and improved ride. The beefy 1.25 by 2 inch connectors are perfect for serious cars with high horsepower, sticky tires or competition suspension. They are reinforced at each bend and include Steeda’s exclusive torque box reinforcing plate for a stronger attachment to the rear subframe.
Full-length subframe connectors are available in bare steel or zinc plated finish. The zinc plating can be welded over, and then only the weld joints need to be spray-painted vs. the whole kit needing to be spray-painted.
Has anyone used these? I like the fact they reinforce your torque boxes and can be purchased with a zinc coating to rid of rust. Let me know what you think. Thanks.
