sticking left front brake
Barry Kelley
Berea, ky.
having Problems with left front brake sticking on a 2001 gt. Have replaced rotor ,caliper, slide pins, hose, and master cylinder still sticking whats next ? anyone else having this problem ? Proportioning valve maybe ?
  • Sponsors(?)
Barry Kelley
Berea, ky.
If this were my car I would look for kinked, blocked or rotten brake lines.
it has all new hoses all four wheels, rotors ,calipers ,pads ,slid pins and even changed master cyl my mechanic is scratching his head. Thanks ! wmburns also this left front was sticking before all new parts with no change
wmburns
SN Certified Technician
Aug 14, 2009
5,811
499
164
Houston Texas
How did you "bypass ABS"?
When the brakes were bleed how was the fluid flow? Especially compared to the other side?
Did you replace all of the break lines or just the flexible hoses?
Barry Kelley
Berea, ky.
Just replaced flex hoses . I don't know how he bypassed wasn't there to see also the car only has 50000 miles on it garage kept.
wmburns
Aug 14, 2009
5,811
499
164
Houston Texas
Soooooooo is it safe to assume it's "possible" the one of the hard lines could be kinked? Have you put eyeballs on the entire length of hard line?
You are aware that one symptom of a kinked brake line is dragging brakes.
I suspect that "bypass ABS" means "pulled the fuse". This still leaves the possibility there's an internal fault.
Barry Kelley
Berea, ky.
I su
Thread starter Similar threads Forum Replies Date
HexMora Rear Right Tire Sticks Out More Than Rear Left Tire. Fox 5.0 Mustang Tech 5
A Right Rear Wheel sticks out little further than left Fox 5.0 Mustang Tech 5
J left wheel still sticking out Fox 5.0 Mustang Tech 3
J left wheel sticking out!!! Fox 5.0 Mustang Tech 4
mybckup Howards rattle stick cams 1996 - 2004 SN95 Mustang -General/Talk- 0
D Oil dip stick tube for 2.3 2.3L (N/A & Turbo) Tech 2
L Brakes sticking 1996 - 2004 SN95 Mustang -General/Talk- 1
Sonicstang0494 Sticking injector? 1996 - 2004 SN95 Mustang -General/Talk- 9
N Clutch Pedal Sticking 2010 - 2014 Specific Tech 3
E Power Window 2015+ (S550) Mustang -General/Talk 4
K 93 convertible rear quarter power windows stick badly going up and down, isolated problem to window regulators Fox 5.0 Mustang Tech 1
7991LXnSHO Electrical Sticking starter solenoid Fox 5.0 Mustang Tech 10
J Oil dip stick length 1965 - 1973 Classic Mustangs -General/Talk- 2
C Stick shift (M6) and no roll - 2015 GT PP 2015+ (S550) Mustang -General/Talk 1
DougieD1961 01 thermostat knob sticking SN95 V6 Mustang Tech 0
M 2006 GT- Shifter Stick Question 2005 - 2009 Specific Tech 1
C 04 V6 Restoration: Stick w/6 or v8 swap? Thoughts? 1996 - 2004 SN95 Mustang -General/Talk- 5
J 92 mustang revs sticking Fox 5.0 Mustang Tech 1
N Blinker Sticks 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
I Auto To Stick Conversion (with A Donor Car) 2005 - 2009 Specific Tech 0
Josecomputertech 2011 5.0 Stick Shift Rearend 2005 - 2014 S-197 Mustang -General/Talk- 3
2000xp8 And This Is Why You Stick To Mm Parts (not Even Steeda) Update Resolved 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 60
Lovejoy Throttle Sticks Fox 5.0 Mustang Tech 3
F Sticking Idle Rpms Raise When Clutch Is Pushed In? Fox 5.0 Mustang Tech 6
R Drivetrain 2011 5.0 Rearend Noise (stick Shift) 2010 - 2014 Specific Tech 1
S 2000 Mustang Gt Mt Gear Stick Seized? 1996 - 2004 SN95 Mustang -General/Talk- 1
dbrufus1234 Stick Shift Newbie Questions 2005 - 2014 S-197 Mustang -General/Talk- 3
stykthyn Brakes Sticking Caliper? Fox 5.0 Mustang Tech 26
I Clutch Disc "dragging/sticking" During Break-in, Normal? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
tamadrummer88 Fastest Stick Shift Mustang 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 17
J Expired Wtb. Drivers Side Gt Convertible Top Trim," Hockey Stick" Interior Exterior Parts 0
dubbsix Suspension Front Wheels Sticking Out 1994 - 1995 Specific Tech 9
mustang.boyle No Oil On Adip Stick SN95 4.6L Mustang Tech 0
F Sticking Clutch Issue 2005 - 2014 S-197 Mustang -General/Talk- 0
L Clutch Issue (sticking) 2005 - 2014 S-197 Mustang -General/Talk- 1
A Sticking Pedal 1991 5.0 Gt 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
gnx547 Oil Dip Stick Tube Won't Go In Fox 5.0 Mustang Tech 10
JasinC19 Engine Mechanic Says Sticking Valve Guides Fox 5.0 Mustang Tech 82
ry94stang50 Sticking Throttle? 1994 - 1995 Specific Tech 9
6 70 Mach 1 That Has Sticking Front Disc Brakes Classic Mustang Specific Tech 3
K 2000 Mustang gt front brakes sticking?? SN95 4.6L Mustang Tech 16
zookeeper Made my own T5 shift stick Classic Mustang Specific Tech 87
TOOLOW91 Electrical Stick Computer In Original Aod Car Fox 5.0 Mustang Tech 16
meltmanbob Towing 90' Stick Shift - Need Quick Advice 2.3L (N/A & Turbo) Tech 21
B Rpms Sticking Something Vicious SN95 V6 Mustang Tech 5
0 2006 Mustang Throttle Sticking /have To Shut Car Down More Than Once To Clear/ Any Ideas On Issue? 2005 - 2009 Specific Tech 4
0 2006 Mustang Throttle Sticking /have To Shut Car Down More Than Once To Clear/ Any Ideas On Issue? 2005 - 2009 Specific Tech 5
NIKwoaC Crazy ass question regarding stick-on side belt molding. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 19
SteedaGT9150 Sticking Gas Pedal SN95 4.6L Mustang Tech 7
5.0Droptop which member here took St Bernard crap put it on a stick listed on ebay? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 24
