My car was overheating and the following parts were replaced. Now my motor is just running 3/4 the way hot. Let me know if you have any ideas???
Water Pump
Radiator
Thermostat (192)
Coolant Temp. Sensor
Temp. Switch
Timing Set 10-12 atdc (with spout conn. out)
Flushed the motor (Test coolant to ensure a 50/50 mix)
Changed spark plugs (.54)
Changed oil
Harmonic Balancer
Cleaned MAF sensor
Running 93 octane
:SNSign:
I have replaced the following parts:Water Pump
Radiator
Thermostat (192)
Temp. Switch
Changed oil
Harmonic Balancer
Cleaned MAF sensor
Running 93 octane
