SOLD Stock And Aftermarket Parts 79 - 95 Some New Some Used Cheap
Rebuilding my 1990 mustang and have original parts for sale cheap. Just need to get rid of some things since I am upgrading. This was a running car that I drove regularly, only reason it is apart is to complete my build. All parts are used but in good working order that can be reused if not labeled new below. All prices are OBO. Please feel free to call me @ 281-755-783nine and make an offer. I stand by my parts and will not sell anything that does not work, I am replacing almost all working parts with all new parts during this build.
- Stock E7 heads with stock 1.6 roller rockers (all EGR tubes, pushrods and head bolts included) - $80
- Stock valve covers - $20
- Hydraulic roller lifters - $20
- BBK shorty headers - $40
- Stock Upper and Lower intake (with good gasket for between upper and lower) - $50
- Harmonic damper - $20
- Stock Radiator - $35
- NEW Stock fan and clutch - $35
- Stock 19 Lb. injectors - $40
- Stock MAF with sensor - $50
- stock timing cover -$20
- stock cam - $80
- stock upper mounts for front struts (has new poly uppers) - $15
- stock clutch, flywheel and pressure plate still in great shape - $50
- NEW YOKON GEAR. Rear axle bearings and seals unopened fits 79-04 mustang - $15
- NEW 87-93 multi function switch (turn signal and wipers) in box never used - $10
- 87-93 headlight switch with fog lamps - $5
- throttle position sensor - $5
- idle air control valve - $ 10
- NEW lower windshield moldings unopened. Two sets. - $5 each
- stock 2.73 ring and pinion gear set - $50
- middle console lid grey - $5
- stock smog pump - $10
- Stock starter - $20
- 17 tooth speedo gear - $5
- Stock throttle body and EGR spacer - $40
Reactions: 1 user
