Hope I can describe the noise and when it happens for someone to shed some light. The noise I hear is ONLY when the brake pedal is applied and the car is moving (you can hear it good doing a low speed <20 mph stop). If I release the pedal while the car is moving, the noise stops. Hit the pedal again, the noise is again there. Once the car is stopped, with the pedal depressed, no noise.
The noise is not the pads/rotors, etc (non-metal). It sounds to be under the hood, a rotating or pumping/valve type noise (aka, hydraulic). A similar noise is heard when the car is stopped and the wheel is turned to the right. Align the wheel to center, no pressure, and the noise stops.
My assumption is power steering pump (cavitation?) or hydro-boost system.
Any thoughts. Thanks.
