Stupid question, thinking out loud
MysteryMachine
1,835
37
Parkesburg, PA
www.mysterymachinegt.com
Ok I know after doing my truck engine that if you bore a block .030 it adds 5 cubes. My 360 went to a 365.
That being said in theory a 351 bored .030 would be a 356.
NOW the real question if you had a 351 bored .030 over to a 356 then added a 408 stroker would it be a 413?
I get the 413 because a 408 stroker "adds" 57 cubes to the 351 sooo 356+57=413
Am I right on this or WAYYYYY off?
  • Sponsors(?)
divit250r
314
Columbia City, IN
The way to figure displacement is to use this formula:
Bore*bore*stroke*.7854*number of cylinders
so, 4.03*4.03*4*.7854*8 = 408
to get a 413 with a 4" stroke, you'd need a 4.053 bore.
Scott
Thread starter Similar threads Forum Replies Date
FastDriver Stupid question about the biggest 5.0 restriction 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 27
CarMichael Angelo Stupid computer question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
G Stupid Questions EGR and Timing Fox 5.0 Mustang Tech 13
Stevenmverrill Post# 1 A Stupid Question And Hi. 1994 - 1995 Specific Tech 26
CarMichael Angelo Stupid Question Time 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 41
yogi4476 Stupid Question, Cooling System 2.3L (N/A & Turbo) Tech 8
I Stupid (simple Question?) High Beam Placement 1965 - 1973 Classic Mustangs -General/Talk- 1
ry94stang50 Stupid Key Fob Question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
mikestang63 Stupid Ground Question Fox 5.0 Mustang Tech 3
R Stupid Question...how Do I Turn Off The Horn Chirp When Locking Car? 2005 - 2014 S-197 Mustang -General/Talk- 1
Tartar22 A stupid question! The Welcome Wagon 2
Z Stupid Question: Do AODEs and T5s have the same Flywheel? 1994 - 1995 Specific Tech 2
N T-5 wc trans swap (really dumb/stupid question?) 1996 - 2004 SN95 Mustang -General/Talk- 4
stevensjustin87 Got a possibly stupid question 2010 - 2014 Specific Tech 4
D Real stupid question Fox 5.0 Mustang Tech 2
R stupid question Fox 5.0 Mustang Tech 0
68stang351 Stupid question about a c4 Classic Mustang Specific Tech 7
P stupid question 1994 - 1995 Specific Tech 13
Noobz347 Stupid/Dumb Question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
J stupid short shifter question? 1996 - 2004 SN95 Mustang -General/Talk- 4
C Stupid MAF conversion question Fox 5.0 Mustang Tech 2
tr7driver Stupid Tuner Question 2005 - 2014 S-197 Mustang -General/Talk- 1
O Another Stupid Wheel and tire Question. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
6 66 Unisteer out tie rod (stupid question) Classic Mustang Specific Tech 8
R stupid easy question SN95 4.6L Mustang Tech 6
Stever89 Stupid question of the day (stroker motors) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
9 Stupid quick question. Need answer ASAP Oil Pump DS retainer 1994 - 1995 Specific Tech 1
jhr302 stupid pole question Fox 5.0 Mustang Tech 10
B stupid question 2005 - 2014 S-197 Mustang -General/Talk- 4
korywiesner Stupid Question! Fox 5.0 Mustang Tech 2
Y Stupid question but need help. Fox 5.0 Mustang Tech 9
maxine-70 stupid piston/con rod question Fox 5.0 Mustang Tech 6
D Dowel Pins next to main caps? (stupid question) 1996 - 2004 SN95 Mustang -General/Talk- 3
kpack5982 Buncha Stupid Fuel System Questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
B stupid question 2005 - 2009 Specific Tech 7
93FiveO stupid questions 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
riceslayer302 stupid question about the vacuum lines on the RPM II upper Fox 5.0 Mustang Tech 3
MysteryMachine Stupid Cam Question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
mhespenh Stupid question of the day: Fox injectors 1994 - 1995 Specific Tech 2
B Stupid Question! 2005 - 2014 S-197 Mustang -General/Talk- 2
D stupid question: what do you call the slide of the back end? 2005 - 2014 S-197 Mustang -General/Talk- 6
fasterthanthem Intake and stupid fuel system question 1994 - 1995 Specific Tech 10
BlownFiveLiter Stupid question, but could I use these...? 1994 - 1995 Specific Tech 2
D Probably a stupid question, but after my Xpipe install... 2005 - 2009 Specific Tech 8
Bikerdrumr Another stupid newbie question 2005 - 2014 S-197 Mustang -General/Talk- 5
stang1986GT Stupid question Fox 5.0 Mustang Tech 0
ras50gt stupid question 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
GT40 2 Stupid question 2.3L (N/A & Turbo) Tech 8
K Stupid Power Steering Question Fox 5.0 Mustang Tech 0
just4bob50 Stupid question about the fuel system Fox 5.0 Mustang Tech 5
