Has anybody tried this fuel system? I'm curious as to how much (boosted) horsepower it can support and what else is needed to complete the setup with some BBRC fuel rails. They're claiming 3/8" stainless steel supply lines, I'm assuming that's bigger than stock? The price is what really has me interested, if it can support 600-700 horsepower, I think it would be a great deal.
https://lmr.com/item/SVE-1021HP-K/SVE-Mustang-High-Performance-Fuel-Line-Kit-w-Fuel-Pump-86-93
PRODUCT DESCRIPTION
Fuel Up Your High Horsepower Motor
This 1986-1993 Mustang SVE high performance fuel line kit w/ fuel pump is a great way to feed more gas into your motor. When making more power in your Fox Body, you are going to need a good fuel supply to keep your power constant. This kit includes a new Aeromotive fuel pump, new fuel pump hanger with 3/8" supply feed & factory bent 3/8" stainless steel supply lines. It also uses factory connection point for an easy installation. This is a great upgrade for Foxbody owners who have increased horsepower and need a better fuel supply. Pick up this kit at LatemodelRestoration.com and get your 5.0 running smoothly again.
Aeromotive 340 Stealth Fuel Pump
These Aeromotive 340 Stealth electric fuel pumps feature a compact, lightweight design that will bolt into most existing hanger assemblies. The 340 Stealth electric fuel pumps boast an impressive 340 lph flow at 40 psi. They are ideal for applications requiring more flow, while retaining the factory wiring and mounting provisions available in the OEM configuration. The Aeromotive 340 Stealth electric fuel pumps use a turbine pump mechanism that increases durability and can be used in pulse modulated applications. These pumps use a 3-inlet configuration that covers a wide range of vehicles. They also run reverse polarity, so they require the use of the included wiring harness for proper installation. The fuel pumps also include a 5/16 in. section of rubber hose and hose clamps.
Application
- Fits 1987-1993 Mustangs
PRODUCT DESCRIPTION
Application
- Replaces Damaged Or Rusted Fuel Lines
- High Performance Fuel Pump
- Stainless Steel Construction
- Pre-Bent Lines
- 3/8" Line
- (1) Fuel Pump Hanger
- (1) Fuel Filter
- (1) Aeromotive Fuel Pump
- (1) Set of Factory bent 3/8" stainless steel supply lines.
- (1) Stainless steel Return Line
