Teksid block or 03?
Charged01cobra
Chenango Forks NY
i know this subject has been beaten to death but i figured i would give it one more shot. First off anyone how do you tell if you have the teksid block without pulling the intake plennum off? second, im getting mixed reports on whats better aluminum or cast 03 cobra? If it turns out that what i got in my 01 cobra now is better looks like i will have a real nice complete 03 cobra sort block for sale.
  • Sponsors(?)
32ValveRom
328
Fl
Uhhh. I'd like to help you out but I'm here at work and don't have access to the SVTperformance page. You should be able to find it on their website.
TDUB
25
I'd go with the Teksid. I have heard of people pushing over 1000hp on them when properly built without any issues.
Supersnake98
Teksid Block
Tecksid blocks were used in 94-98 Lincoln Mark 8 and 96-99 Cobra Applications and are the best Aluminum block for 4.6L use. I picked up an entire 95 Mark 8 longblock several years ago for $200, just add good rods, forged pistons, and a Cobra forged crank with proper prep and you have a 600-800 Hp capable engine.
Paul
Gearbanger 101
Straight Outta Locash
Super Mod
Aug 10, 2002
9,457
1,376
234
Ontario, Canada
I've heard Teksid blocks are actually good for somewhere in the 1,200hp range, but so what? Unless you're making upwards of 800hp, it shouldn't matter which block you're running....either will do fine with the right internals.
TDUB
25
I can tell you this first hand > the alum is much lighter !! a steel block I can lift but it's heavy > my alum block I can lift over my head with the crank in it >
I believe the offiicial weight of each block is 85 lbs. for the aluminum vs. 153 lbs for the iron.
Charged01cobra
Chenango Forks NY
thats what i figured, but now can anyone tell me how to find out if i have the teksid block or not without removing the intake? by the way, just finished pulling out my tranny tonight amazing how much easyer it is to get out with that quick time bell housing. anyone here know where i can find some diagrams or info on rebuilding my TKO.... 2ed gear grinds into gear and so does reverse unless your sitting still with the clutch in for about 5 seconds or wait the same amount of time driving down the road into 2ed.
Thread starter Similar threads Forum Replies Date
H Teksid Block in 05 to 09 3V? 2005 - 2014 S-197 Mustang -General/Talk- 2
Z 4.6 teksid block cheap?? 1996 - 2004 SN95 Mustang -General/Talk- 0
Chris98Stang Getting Ready To Buy A Teksid 4.6 Block, Many Questions On Build And Fi SN95 4.6L Mustang Tech 28
99Blownstang teksid block and kenne bell SN95 4.6L Mustang Tech 1
R Ford Teksid aluminum 4.6L block SVT Tech Forum 4
6 FS: Ford Teksid 4.6L aluminum block Engine and Power Adder Parts 2
T Teksid block with sohc heads SN95 4.6L Mustang Tech 10
mikedj Teksid short block all forged parts Engine and Power Adder Parts 6
T 1993 mark VIII engine , Teksid aluminum block Wheels Tires Brakes 1
M Teksid Block & Forged Crank FOR SALE... Drivetrain Parts 1
bhuff30 Teksid Block and NPI cams/intake Engine and Power Adder Parts 1
jeremy canter Teksid alum block and 8-bolt crank Engine and Power Adder Parts 13
Back2Mustangs Built, PI, 4.6L Mod motor (Teksid block) Pan to Valve Covers $4800.00 (DFW, TX) Engine and Power Adder Parts 0
Back2Mustangs Built, PI, 4.6L Mod motor (Teksid block) Pan to Valve Covers $4800.00 (DFW, TX) Interior Exterior Parts 0
JymboSlice Gt timing cover on teksid block 1996 - 2004 SN95 Mustang -General/Talk- 1
Y Teksid block, H beam rods and cobra crank for sale Engine and Power Adder Parts 8
2 Teksid Block and 03 Cobra Crank Engine and Power Adder Parts 2
J Teksid block SVT Tech Forum 7
R teksid block in a newer stang 2005 - 2009 Specific Tech 5
S teksid block into 2v?? SN95 4.6L Mustang Tech 4
DOHC otto Teksid Block Questions SVT Tech Forum 17
A How much more can a Teksid block handle? SN95 4.6L Mustang Tech 9
NeverFastEngh Teksid Block Question SVT Tech Forum 15
H How to identify Teksid block? SN95 4.6L Mustang Tech 2
Back2Mustangs Teksid blocks in Mark VIII's...what years? SN95 4.6L Mustang Tech 10
C Teksid aluminum block SN95 4.6L Mustang Tech 11
Venom_Nitrous Teksid block #'s, is this one?? SN95 4.6L Mustang Tech 1
95TT347Cobra BEST SWAP OPTIONS! 05 GT 4.6 3v (Threw Rod), I have a 4.6L 2v out of an 04 GT and 4V in A mark. Suggestion? 2005 - 2009 Specific Tech 2
95TT347Cobra 05 S/C GT Teksid swap??? 2005 - 2014 S-197 Mustang -General/Talk- 1
Z Engine 2004 Mustang gt teksid swap questions SN95 4.6L Mustang Tech 0
Bob Hughes Engine Teksid Build Update.... SN95 4.6L Mustang Tech 26
Bob Hughes Engine Teksid Main Cap Bolts SN95 4.6L Mustang Tech 3
Bob Hughes Teksid Main Cap Bolts SVT Tech Forum 0
Mr. Rustypwnz Found the limit on a stock teksid 2v 1996 - 2004 SN95 Mustang -General/Talk- 14
TenorPlayinGuy Contemplating a Teksid swap... ideas :) 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
usaf_branham teksid shortblock as an option? SN95 4.6L Mustang Tech 4
Mr. Rustypwnz nitrous on a teksid 2v? 1996 - 2004 SN95 Mustang -General/Talk- 9
Mr. Rustypwnz teksid 2v gt is alive!! 1996 - 2004 SN95 Mustang -General/Talk- 14
LaserSVT Teksid 4V complete engine. Engine and Power Adder Parts 1
B Help with 2V Teksid SN95 4.6L Mustang Tech 3
billfisher forged teksid 1996 - 2004 SN95 Mustang -General/Talk- 45
Z teksid swap, questions SN95 4.6L Mustang Tech 5
LaserSVT I thought Teksid was good? SVT Tech Forum 3
Back2Mustangs Buying Teksid this week... need crucial ?'s answered b4 purchasing SN95 4.6L Mustang Tech 34
F I'm a moron and cracked my block. Is this fixable? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
N Head gasket size after boring block? 1996 - 2004 SN95 Mustang -General/Talk- 1
WarHorse66 Can i use roller cam parts in 81 block. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
Foxbody1995 Junction block Fox 5.0 Mustang Tech 2
S 4.2 crank/rods/pistons in a early non roller cam 3.8 v6 block ? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
65-Fstbk Brake distribution block help - Granada swap 1965 - 1973 Classic Mustangs -General/Talk- 0
