Needs new tires for sure. The Michelins on there are over 8 years old and they're dry-rotted all to hell - one on the left-rear is slowly leaking air because of this. That, and they're undersized which not only looks goofy but also has my speedo reading all weird.
The list of immediate must-haves is short:
1. Tires;
2. Speedo cable and/or gear (goes crazy and bounces around when over 55 MPH);
Stuff that I would LIKE to fix/replace but can't afford to yet (probably won't for a long while) and I can let go for the time being:
1. Radio (gonna use the one that's currently in Stinky when I can afford a better unit);
2. Valve cover gaskets;
3. New plug wires and Motorcraft plugs (those platinum Autolites in there suck, but they're brand-new);
4. Paint/clean a few pieces in the interior (dash, headliner, some random little stuffs);
5. New front driver's seatbelt latch (spring for the button is broke - it latches and holds, but I don't trust it);
6. Dual exhaust conversion (soon as I figure out how to relocate the external fuel pump and filter);
7. New motor mounts (rubber 'vert mounts or poly mounts, whichever)
8. Sand and repaint air cleaner assembly (and maybe throw on a 4v sticker instead of EFI, in case I go carb'ed, as it might lead the Smog Nazis not to think twice about it being carb'ed);
9. Touch up exterior paint the prior owner totally screwed up (mostly around the lower half of the front and rear bumpers);
10. Finish the centerline pinstriping around the rear bumper OR locate and slap on all the proper centerline trim (it's missing all the mouldings from the front to the back on both sides);
11. Locate and install missing driver's side lower rocker panel trim piece (dunno if it's a stock piece or aftermarket);
12. Finish fixing that damned LX wing by bolting it down properly, sealing the bolts, and wiring that sucker up so that the third brake light actually works;
13. T-5 conversion ;
14. Maybe a carb or roller-motor conversion (in the far, far future);
That's all I can think of at the moment.
1. Tires;
