Build Thread The Hoopty Chronicles - New House, New garage, New Car?
CarMichael Angelo
clearly, I’ve got something going on in that hole
SN Certified Technician
14,179
234
62
Birmingham, al
m.imdb.com
I think I can put my imbalance theory to bed.
SCAT only makes 1 cast 3.5" crank, and it's 28oz external. the flywheel was from the old motor and works fine. I double checked the damper p/n and it's for sure a 28oz damper. The parts are all correct in that regard. I'm headed home in a few minutes to go cut the filter open
He did resize the rods, there were 3 that needed some work.
The balance is the issue I think. I can honestly say I didn't know. I thought 28oz was 28oz. I mean... say you get a new flywheel on an engine that's been running for a while. Do you have to pull the whole engine apart and rebalance everything? Same for a balancer... The old one disentegrates and you replace it. Pull the whole engine apart again? That doesnt make any sense to me.
everytime they've resized my conn rod, all 8 got worked. They grind a small amount off of the cap, and make the opening smaller, then open it up to the correct diameter.
As for your vibration, if you have a rod bearing leaving you, then that rod is what you're feeling I think, unless it was that way from minute one.
I realize that this is a big pita, but Think about this, it's how I rationalized pulling my engine out to fix the leaks..
How much time does it really take?
A day to pull it?
A day to pull it apart?
A day to get it to a place to fix it?
Then reverse the process..
A week out of your life doing car guy stuff.
  • Sponsors(?)
hoopty5.0
mechanicus terribilis
Mod Dude
Dec 14, 2010
7,324
6,249
204
SW Houston
A day to pull it?
Yes to all, BUT you've got time to do that. How old is your youngest now? I don't have that luxury anymore.
*edit
Forgot money. Take it to a machine shop -the whole short block with directions to:
- disassemble
- clean everything
- machine anything thats FUBAR
- balance everything
- reassemble it all
What's that gonna be, $1500??
CarMichael Angelo
14,179
234
62
Birmingham, al
m.imdb.com
*edit
- disassemble
- clean everything
- reassemble it all
You could always take up golf.
Shoes, clubs, lessons, and hundreds of dollars spent on greens fees, new "magic" putters/drivers, dozens of balls lost in the woods, and at the bottom of the lakes.
Then, after thousands of dollars spent trying to get good, and never ever breaking par.....
You're wondering......what the hell am I gonna do with all this crap now?
Reactions: RangerJoe
hoopty5.0
Mod Dude
Dec 14, 2010
7,324
6,249
204
SW Houston
I’ve got a bunch of brewing and distilling apparatus i need to get back in to
hoopty5.0
Mod Dude
Dec 14, 2010
7,324
6,249
204
SW Houston
Im also kicking around parting out the 351 stuff. Theres a complete 302 intake to pan locally for $1500 that I could plop in and be cruising really soon. I could make that easily with the 351 parts and turbo stuff
Reactions: General karthief
HotFox
973
558
134
40
SE Michigan
I really hope you keep it! I am doubtful that the balance took out a bearing. Never say never. In a unbalanced situation the outside edge of the main will show scrubbing this is from loss of oil film due to crank flex. This usually will not lead to bearing failure as it would have to extremely severe by destroying itself or drive trash into the rod journal further worsening the situation. I once had a 350sbc and put a 400 externally balanced balance on it. Had a vibration but it did not kill it swapped to the correct balancer and away it went.
Scott
Reactions: hoopty5.0
tannerc91gt
This last 25% is foreign territory at this point
3,058
234
Indiana
Is that really what those old things cost these days?
hoopty5.0
Mod Dude
Dec 14, 2010
7,324
6,249
204
SW Houston
Scott
You’re always good for experienced advice, thanks! If they guy that came tonight doesn’t buy it, I’ll keep it. Momma gave me permission to set funds aside for a few months. Maybe by then I’ll feel like pulling the motor out and taking it to a machine shop to be fixed and built the right way!
Thread starter Similar threads Forum Replies Date
hoopty5.0 Progress Thread Hoopty5.0's non-hoopty-clean-up-project 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 656
H New from CO w/ hoopty sleeper project 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 14
hoopty5.0 The Totally Awesome Adventures Of Boosted And Hoopty 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 25
hoopty5.0 The Hoopty Still Lives. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 13
hoopty5.0 Build Thread The Hoopty Build Fox 5.0 Mustang Tech 352
D Pimp My Hooptie Sukkas! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 49
SMOKEDYA The hooptie is dead!!! Regional Forums and Event Information 0
94GTLaserRC Got Myself A HOOPTY!!! 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 27
SMOKEDYA Question with the hooptie? Regional Forums and Event Information 2
94GTLaserRC Help Me With This Hoopty Choice. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 22
mustanggt350 steppin out in the hooptie!! Regional Forums and Event Information 10
BoostedmaxPSI Roush OT: Chronicles from a cell phone Special Production 7
S WTB/Trade Looking for a 1999-2004 axle housing Drivetrain Parts 0
Olivethefet Drivetrain One Man T5 Tailshaft Housing Install In The Car Fox 5.0 Mustang Tech 6
Rdub6 Fuel Fuel Filler Neck Housing Removal Fox 5.0 Mustang Tech 7
S T-5 input shaft for a Mustang 2 Bell housing 1974 - 1978 Mustang II Talk & Tech 7
Rxbandits Ford MAF w/C&L 76mm housing Fox 5.0 Mustang Tech 38
V Help with bellhousing issue. The Welcome Wagon 5
J Thermostat Housing- leak that wont stop 1974 - 1978 Mustang II Talk & Tech 19
J tail light housing 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
Olivethefet What's it Worth? T56 value What is it Worth?!?!? 3
3 Expired Tremec TKO 600 5 spd .64 O/D w/ bell housing Drivetrain Parts 4
A Help!!!!! 1993 Mustang coolant sensor inline T housing 2.3L (N/A & Turbo) Tech 4
robthechemist Any benefit to upgrading the top loader bell housing to a T5 bell when doing a T5 conversion? 1965 - 1973 Classic Mustangs -General/Talk- 2
O One Bell Housing Bolt holding me up 2005 - 2009 Specific Tech 2
D Thermostst housing bypass outlet 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
P 97 mustang gt an I put a 75mm throttle body a bigger throttle body housing an now my is running like crap 1996 - 2004 SN95 Mustang -General/Talk- 3
K Fox Bell housing has broken dowel hole 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
D 1966 manual bell housing 1965 - 1973 Classic Mustangs -General/Talk- 2
FastDriver Best t-stat housing available on the market today? or any housing w/o the inevitably leaking bleeder screw... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
M 2000 ford mustang gt bell housing 1996 - 2004 SN95 Mustang -General/Talk- 1
C Can 9” internals be used in a 9.3” housing 1965 - 1973 Classic Mustangs -General/Talk- 2
lenko WTB/Trade WTB Saleeen Series VI.5 Mustang Supercharger Housing 2 piece like below for 2006 Mustang located in Lethbridge, AB Canada. Other Classifieds 0
K Stock Air Filter Housing... Fox 5.0 Mustang Tech 4
M SOLD T5 To 4.0 Bell Housing Drivetrain Parts 0
W Turn Signal Housing Brackets 2005 - 2014 S-197 Mustang -General/Talk- 1
jimonlight Coolant System Fun!!! 2010 - 2014 Specific Tech 1
J 1974 Mustang V6 Bolt Problem In Thermostat Housing 1974 - 1978 Mustang II Talk & Tech 2
AlohaStang1 Transmission Extension Housing Bushing/seal Replacement 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
Vic's 65 mustang Hello All! 1965 Mustang Owner In The House. The Welcome Wagon 3
theshadow007 Thermostat Housing 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
F Engine Oil Leak Only When Engine's Cold Fox 5.0 Mustang Tech 12
G Cracked Bell Housing 1996 - 2004 SN95 Mustang -General/Talk- 4
6 Expired Welded, 9" Big Housing Ends, Powdercoated Ford 8.8 Sra Drivetrain Parts 2
R Bell Houseing Engine and Power Adder 1
9 Expired 87-93 Gauge Cluster Bezel Interior Exterior Parts 2
S Fox C4 Bell Housing Id 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
B Drivetrain Transmission Trouble In My 93 5.0 5 Speed Tail Housing Cracks Fox 5.0 Mustang Tech 3
B Transmission Troubles T5 93 Mustang 5.0 Tail Housing Cracks 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 10
R Thermostat Housing 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
