When your ready hit me up, I will play wingman.
Been right where you’re at multiple times. The worst time being my MS3.
You say it runs for a couple seconds and dies but are confident it isn’t ignition related now.
Does cracking the throttle result in anything?
Also, have we verified everything on the fuel supply side?
Pump runs more than just priming before start, consistent fuel pressure that doesn’t fall off, injector voltage good?
I’ve had a whole host of mechanical issues hold me out as well as a fuel map and IAC settings that made engine run just long enough to get your hopes up
ok, I adjusted my statement. I'm also going to readjust the valves and check on the fuel system, just for good measure.I have nothing other than to concur with Steve. Iowa Nick's car was a " no start" for .............days? When he last attempted to start it after swapping engines.
For him it was over tight valve adjustment.
What's that roundish thingy with the wires coming out of it?I have sinned.
No, couldn’t get any trigger input. Then I realized I forgot to change all the jumpers back, but it was late and I was hungry so I quit for the night.But does it run? If it does mail me those coils.
I’ve gone too far to give up. I’ve got one more Hail Mary in meF it bro! If the distributor fixes the problem then just leave the dang thing in there and get to tuning and enjoying the car!! If you don't then you're just a Masochist, lol. Good luck either way Colin.
