- Oct 30, 2008
- 201
- 2
- 16
I found this in another forum, is this safe to do or anyone try this?
here is a trick i have used for years and it has worked every time....
get about 1/2 quart of desil fuel and pour it into your oil,drive around for a few ours or a day or two right befor an oil change, make sure u drive in a gear lower then u uausaly do(if its a 5 speed) to keep the rpm's up to keep your oil pressure up.the heat of your engine plus the desil fuel breaks all the sludge that are blocking and clogging all your oil ports and the desil is oil based so its safe on bearings and internal parts it wont dry it out. then change your oil and all that nasty stuff will come out with it. i also reccommend changind your oil filter about half way through your next oil change to catch any debris that is still in there.
there is a product at your autoparts store for like 6 dollars but IMO the desil works better and it only cost about .50 cents...
it was funny i did it in my VW and i drove up to the pump poped my hood and put the desil nozzle right in the oil fill hole everyone at the gas station was like ate you crazy lol..
