Throttle Response Delay... ???
AnthonyR23
661
Ontario
Hi.. just wondering what could be causing this.... my car doesn't seem to have the same response as it used too... I used to feel like it was fast... but it seems like when I give it gas it hesitates before waking up.... what could be causing that? Didn't used to do it.. I haven't replaced the fuel filter since I bought the car... could that be a problem?? If so how hard it it to replace?
  • Sponsors(?)
88 pos gt
29
That could be a problem, the fuel filter is at the between the rear bumper and fuel tank, it takes five minutes to change. All you need is a catch pan and a Phillips and flat head screw driver. Also don't forget to unplug the negative on your battery.
Good luck
P.S. Try not to break the plastic tabs that are on the fuel line. That could be bad.
HISSIN50
SN Certified Technician
28
129
Dump the codes. This would be a time where a soft code could be stored (without illuminating the CEL).
Also, do you know if you have any vacuum leaks?
Good luck.
Thread starter Similar threads Forum Replies Date
tealstang67 delayed throttle response 1994 - 1995 Specific Tech 7
RedDaemon delay in throttle response Other Auto Tech 8
A Lag/delay in throttle response Fox 5.0 Mustang Tech 4
A Throttle response delay and hanging idle... Fox 5.0 Mustang Tech 6
T Losses Throttle Response Fox 5.0 Mustang Tech 2
F Idle Surging Problems Fox 5.0 Mustang Tech 6
Slo5Oh89 89 Throttle Response Fox 5.0 Mustang Tech 7
P Throttle Response? 2010 - 2014 Specific Tech 7
9 Loses Throttle Response In 2nd Gear Fox 5.0 Mustang Tech 10
P Weird Throttle Response 2005 - 2009 Specific Tech 4
flashback87 Explorer Tb/throttle Response? Fox 5.0 Mustang Tech 1
cdurbin Engine Throttle Response Fox 5.0 Mustang Tech 19
JordanB21 Digital Tuning Throttle Response, Rpm Jumps, And Other Questions. 1994 - 1995 Specific Tech 7
stanger9410 throttle response? 1994 - 1995 Specific Tech 5
R Rough Idle and rough throttle response!! GROSS!! 1994 - 1995 Specific Tech 1
smilts no throttle response, sporatic idle 1994 - 1995 Specific Tech 43
ryangruhn No throttle response when floored, "Popping" sound? Fox 5.0 Mustang Tech 12
tkd3rd THROTTLE RESPONSE 2005 - 2009 Specific Tech 5
C How to get better throttle response? Fox 5.0 Mustang Tech 5
8 No Throttle Response Fox 5.0 Mustang Tech 3
D Mods for quicker throttle response? SN95 4.6L Mustang Tech 13
purplestang90 Slit hisitation in throttle response? Fox 5.0 Mustang Tech 3
Pokageek Does a smaller bladed TB give a better throttle response? Like 75 mm inst of 80mm? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 47
MikeROD16 Weird Throttle Response Fox 5.0 Mustang Tech 0
9 Poor Throttle Response Fox 5.0 Mustang Tech 3
MikeROD16 late throttle response Fox 5.0 Mustang Tech 5
N Poor throttle Response Fox 5.0 Mustang Tech 9
T DIY: Throttle response mod (MUST SEE) 2005 - 2009 Specific Tech 12
K Poor Throttle Response 2005 - 2009 Specific Tech 3
Skud Quest for throttle response... SN95 4.6L Mustang Tech 12
L Throttle response and other things... 2005 - 2009 Specific Tech 6
Foxfan88 no mufflers cause less throttle response?? Fox 5.0 Mustang Tech 20
M bad throttle response Fox 5.0 Mustang Tech 4
98gt46 98 4.6 Poor Throttle Response. Loss Of Power 3500 - 4800 rpm range SN95 4.6L Mustang Tech 6
D slow throttle response SN95 4.6L Mustang Tech 5
willys1 Need help with off the line throttle response Fox 5.0 Mustang Tech 8
Pokageek How's your pedal feel or throttle response?... 1994 - 1995 Specific Tech 15
88 Fox GT My MAF engine has better throttle response than my SD engine. Fox 5.0 Mustang Tech 6
S Bad throttle response need help please Fox 5.0 Mustang Tech 6
M Throttle Response SN95 4.6L Mustang Tech 8
NIN Throttle response 1994 - 1995 Specific Tech 2
B Throttle response? 2.3L (N/A & Turbo) Tech 20
stingeragent Poor throttle response 1994 - 1995 Specific Tech 0
TweekedGT Poor Throttle Response SN95 4.6L Mustang Tech 1
H question on throttle response?? Fox 5.0 Mustang Tech 4
N Throttle Response Fox 5.0 Mustang Tech 4
C poor throttle response -help- Fox 5.0 Mustang Tech 1
BlackVert i need better throttle response! 1994 - 1995 Specific Tech 9
BelueLX vaccum secondaries -vs- mechanical... throttle response Fox 5.0 Mustang Tech 1
BelueLX vacuum secondaries -vs- mechanical... throttle response Classic Mustang Specific Tech 10
