So as some background my 94 gt has been running well recently replaced the distributor, act sensor, icm, ect sensor, and did an intake swap to a TFS street burner series months ago and got an sct chip for a tune. I was on my way to town in some heavy rain a few days ago when a car splashed a large amount of water onto my (ram air) hood and windshield shortly after my car started cutting out a little like it had some old fuel in it, on the same trip that happened twice more and when I came to a stop the car stalled on me and would not start back up until I advanced the timing to approx. 30* advanced it will not start otherwise and is very hard to start at that point, once started I can only drop the timing to about 18* advanced then it stalls, when driving it backfires and has no power I assume due to being way too advanced on timing. I took it in to a shop after doing a few various tests of my own and they swapped in all new parts mentioned above other than intake, tested fuel pressure, and for vaccum leaks the only thing they didn't test was the maf they inspected it and said it appeared ok but couldn't swap a new one in to check the difference if any, or if it had jumped timing which they don't believe it had, the only thing I can think of is the maf sensor was damaged by water but I would like some input from others. ( sorry for the novel just wanted to put in as much info as possible) update: the maf and ait sensors ( same plug for both sensors) have .038v on the ground wire
