Tranny Help!
Clutch alignment tool, the plastic ones are about $3 at most auto parts stores. It looks just like the input shaft of the transmission. You use it to line up the clutch disk with the pilot bearing hole. It makes the job simpler, as the clutch disk is almost perfectly aligned when you silde the transmission in place. As Timmy2734 said, you may have to push in on the clutch pedal to get it to go the last 1/2". I used some 7/16" threaded rod screwed into the mount holes to help align the trans.
