M.P. Cobra Fan New Member Aug 10, 2007 19 0 0 Atlanta GA Oct 18, 2007 #1 Oct 18, 2007 #1 I am going to change the fluid on my 3650 this weekend. I wanted something non-synthetic and was told to try an ATF. Have any of you tried Hurst Hot Shift or B&M Trick Shift? If so, opinions? Or other recommended brands?
RandyStinchcomb New Member May 25, 2005 1,159 2 0 Randallstown, Md Oct 18, 2007 #2 Oct 18, 2007 #2 just go buy some Mercon III
LouisianaZJ Member Feb 13, 2004 237 0 17 Oct 19, 2007 #3 Oct 19, 2007 #3 I am using Royal purple synchro max. Noticable improvement http://www.royalpurple.com/prodsa/scmax.html
Superhereaux chicks make me feel inadequate Founding Member Jul 30, 2002 538 3 59 South Texas Oct 19, 2007 #4 Oct 19, 2007 #4 i used Castrol Domestic Vehicle ATF it's just a fancy name for good 'ol Mercon/Dexron III
CobraRed_96_GT Active Member May 20, 2006 1,421 3 39 UCSD/La Jolla Oct 19, 2007 #5 Oct 19, 2007 #5 LouisianaZJ said: I am using Royal purple synchro max. Noticable improvement http://www.royalpurple.com/prodsa/scmax.html Click to expand... Plz don't. They use additives that no transmission needs and their resistance to erosion and Forced pressure+heat tests rank the 2nd to lowest and lowest of 12. If i find the independent test .pdf ill post it.
