Turn signals do not cancel automatically.
ngiotta
18
California
After removing the steering wheel in my son's 95 Cobra, the turn signals have stopped canceling after straightening the wheel. Well, I should stipulate that they do auto-cancel about 10-15% of the time. Anyone else have this problem? The switch works fine otherwise, but could it still be bad, loose, or...?
  • Sponsors(?)
Admin Dude
Jan 4, 1985
28,923
10,898
224
Box behind Walmart
www.stangnet.com
You could try removing and reinstalling the combination switch but if it were me, I wouldn't do it without having a new one on-hand to replace it with in the case that it self-destructs when you pull it.
It's probably toast anyway but there's a chance it's just binding up after putting the wheel back in.
ngiotta
18
California
Thanks for the response. I think I might have over-tightened the steering wheel, if that's possible? It was moving slightly, up and down (still does, a little), so I tightened the crap out of that T50 bolt.
2000xp8
SN Certified Technician
Aug 8, 2003
6,901
1,032
194
NJ
I'm not aware of how the 95 wheel goes on.
Is it splined?
Your description makes it sound like you pulled the wheel, put it back on in a different spot to straighten it.
Where's in most situations I would believe that type of adjustment needs to be made at the rack and shaft.
I've also had on another ford vehicle a little knub break off the arm. Couldn't tell what the issue what until I had a second one in hand.
Regardless, I would think you could remove the stalk and manually trigger the cancel.
I doubt you could over tighten it. The movement is probably in the shaft, not the wheel.
trebor3170
mine usually gets hard with the car on
May 31, 2019
98
38
28
62
Salisbury, MD
95 Mustang has 2 flats on the shaft, the wheel will only go on one of two ways. I think what he meant by straightening the wheel, is after a turn.
Thread starter Similar threads Forum Replies Date
P Electrical Turn Signal "over" Cancelling Classic Mustang Specific Tech 2
Joe Medeiros Turn Signal Won't Cancel 1965 - 1973 Classic Mustangs -General/Talk- 6
J Need help finding turn signal cancel cam for '68 Mustang Classic Mustang Specific Tech 7
C Turn signal cancel collar positioning on steering wheel Classic Mustang Specific Tech 4
N Turn signal not canceling Fox 5.0 Mustang Tech 1
C turn signal cancel cam not working with Lecarra wheel, ideas?? Classic Mustang Specific Tech 2
D 1968 Turn signals 1965 - 1973 Classic Mustangs -General/Talk- 0
Foxbody1995 Left turn signal Fox 5.0 Mustang Tech 9
Foxbody1995 Left turn signal Regional Forums and Event Information 2
G Front turn signals don’t work Fox 5.0 Mustang Tech 10
6 For Sale Headlamps, Turn signals etc Interior Exterior Parts 1
M Turn signals and wipers not working The Welcome Wagon 1
J No turn signals, hazzards, and taillights 1996 - 2004 SN95 Mustang -General/Talk- 1
Foxbody1995 Turn signals issues 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
S Turn signals on a 68 coup no work but flashers do 1965 - 1973 Classic Mustangs -General/Talk- 0
B Electrical 1987 GT turn signal/hazard light problem Fox 5.0 Mustang Tech 1
Lake Martin John LED turn signal conversion 1965 - 1973 Classic Mustangs -General/Talk- 0
S Turn signal issue Fox 5.0 Mustang Tech 53
L 2016 Front turn signals won't flash 2015+ Specific Tech 1
A Electrical Turn signal relay 2010 - 2014 Specific Tech 0
Tavis 89 LX 2.3L - Turn Signal and Backup Light intermittently works 2.3L (N/A & Turbo) Tech 1
S Electrical Oh no not another 88’ turn signal thread! Fox 5.0 Mustang Tech 6
P Brake lights and rear turn signal mystery 1965 - 1973 Classic Mustangs -General/Talk- 0
P Brake and rear turn signal lights mystery Classic Mustang Specific Tech 0
M Why is my left turn-signal light always lit?!! Fox 5.0 Mustang Tech 8
M Help Turn signal issues 2005 - 2014 Specific V6 Tech 0
fiftyslost Sequential turn signal. 2005 - 2009 Specific Tech 0
realtex 95 GT turn signal problem 1994 - 1995 Specific Tech 1
Boricua86 Electrical 1986 GT Turn signal / Hazard lights relay locations Fox 5.0 Mustang Tech 3
Dustin2v Electrical Sequential Turn Signals not working on one side? SN95 4.6L Mustang Tech 5
C Electrical 99 GT - Front Turn Signals not working SN95 4.6L Mustang Tech 4
W Tail lights flash when I turn signals are on Classic Mustang Specific Tech 0
A Electrical Headlight and turn signal problems Fox 5.0 Mustang Tech 3
B Progress Thread My 16's rear turn signal indicator 2015+ (S550) Mustang -General/Talk 1
V Get Sequential Turn Signals Back 2015+ (S550) Mustang -General/Talk 0
S Turn signal 1996 - 2004 SN95 Mustang -General/Talk- 1
D Help for Turn Signal problems 1996 - 2004 SN95 Mustang -General/Talk- 2
S 67 turn signal hood inserts Classic Mustang Specific Tech 0
S The Dreaded,No Brake Light,Hazard or Turn Signal for 94-04 Mustang. SN95 V6 Mustang Tech 0
E Rear Lights w/Amber Turning Signal 1996 - 2004 SN95 Mustang -General/Talk- 2
V Turn signal switch connector issue 1994 - 1995 Specific Tech 9
candphall Scoop mounted turn signals 1965 - 1973 Classic Mustangs -General/Talk- 5
FetusLasVegas Electrical 89 GT, Front turn signals not illuminating with headlights Fox 5.0 Mustang Tech 2
G Brake Light/turn signal issues 1965 - 1973 Classic Mustangs -General/Talk- 1
T 1968 mustang turn signals 1965 - 1973 Classic Mustangs -General/Talk- 4
Y trouble with 70 mach hood turn signal Classic Mustang Specific Tech 1
candphall Turn signal 1965 - 1973 Classic Mustangs -General/Talk- 12
MCF84 15-17 Front Turn Signal Swap 2015+ (S550) Mustang -General/Talk 2
H Turn on blower motor and right turn signal flashes 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
F Turn Signal Problem 1994 - 1995 Specific Tech 6
