Unknown connector
Matthewrein
Texas
I'm currently doing a swap with a 93 5.0. This has been interesting as I have no clue how this engine is run(which wires are which). Does anyone have a picture of the harness that has the connectors labeled? Or if you could just tell me what this goes to.
  • Sponsors(?)
Mustang5L5
i'm familiar with penetration
Mod Dude
Feb 18, 2001
33,071
9,212
224
Massachusetts
That's also not a 93 Mustang intake manifold.
That particular harness you are holding is not fox body Mustang in origin
67coupe
636
365
83
Huntsville, AL
Need some additional info. Definitely not a fox body, wiper motor on pass side. What car? Engine?
That is definitely an SN-95 harness.
Matthewrein
Texas
Yeah sn95, its a 15 pin connector. I'm trying to find the pigtail that gets power sent to it for the ecu and the injectors and the like.
VibrantRedGT
"STANGNET'S PENGUIN SMACKER"
434
144
49
Boca Raton, Florida
www.mustangworks.com
Yes, you have a 94-95 Engine and Harness.
In you hand is the external harness that goes to everything in the engine bay.
The other side of that connector goes into the car from the passenger firewall to the ECU. Do you have that?
Untitled by jpjr50, on Flickr
Matthewrein
Texas
No, all I have is the harness directly from the Ecu to engine bay the only two other harnesses that connect to the main one are for the injectors and starter. Am I missing some?
VibrantRedGT
434
144
49
Boca Raton, Florida
Car isn't starting with out the other side. Unfortunately for you that other side of that connector you need is in a 94-98 Mustang. You're gonna have to find one at a salvage yard and take it out yourself. Maybe you can find one already removed.
I assume you're also missing the harness inside the passenger fender. That one has the Ignition module and timing spout. It also connects to your missing connector. Also runs to the CCRM module (black box in front of the radiator).
Let me see if I can find pictures.
Go to 8:29 of my video. Do you have this wiring harness for the passenger side fender? Has connections for the A/C, MAF, IAC, CCRM, etc.
View: https://www.youtube.com/watch?v=2FPW6LmAsUc&t=11s
Matthewrein
Texas
Alright I'm really confused lol. I'm gonna tell you what I have. Starting from the Ecu and through the firewall I have all of that. It then splits off three ways, 1(main harness that goes to the ccrm, ign module, alt and the like) 2(big connector that then connects to the injectors, distributior, etc..)
3 (the mystery plug, it's female 2ith about 15 wires going to it) I have the harness that runs to the starter and o2 plugs and oil pressure gauge, which connects to the #2 split off mentioned above. Im looking for where to run power too for the Ecu, sensors, and the ccrm. Would this connector be the one I feed power too?
Hoytster
I don't dare do that to my Knob
908
572
134
37
Cornwall, PA
www.hoytspot.com
Not sure if this will help, but either way this will be good info to have. Here is the engine harness layout for a 94-95 mustang, as well as the EEC-IV pinouts and wiring colors. As others have stated, I believe that is the harness that goes to the passenger side fenderwell.
  • Informative
Reactions: jozsefsz
Thread starter Similar threads Forum Replies Date
B Unknown connector 1996 - 2004 SN95 Mustang -General/Talk- 1
P Unknown Connector On Intake Tube 1996 - 2004 SN95 Mustang -General/Talk- 2
Jacobhollis Unknown tune! 2010 - 2014 Specific Tech 1
N Unknown line.. vacuum maybe?? SN95 4.6L Mustang Tech 3
P Unknown black plastic debris falling from behind glove box 1996 - 2004 SN95 Mustang -General/Talk- 2
A Unknown 1996 - 2004 SN95 Mustang -General/Talk- 2
FastDriver Fox Poll: Which wheel do you like more. Black ponies or old unknown wheels? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 43
G Electrical Unknown Relay behind glovebox SN95 4.6L Mustang Tech 7
B Engine 2000 GT unknown maf computer and underdrive pulley. SN95 4.6L Mustang Tech 2
G Unknown cam 1994 - 1995 Specific Tech 0
gharger 2000 4.6 Vortech tune unknown Digital Self-tuning Forum 5
foxbodystang89 Fox Unknown part under foxbody hood 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 3
9 Unknown fuel issue. Fuel pump not turning on 1994 - 1995 Specific Tech 1
J 1971 Mach 1 fastback unknown part under dash 1965 - 1973 Classic Mustangs -General/Talk- 0
S Unknown sound from clutch! 2005 - 2014 S-197 Mustang -General/Talk- 2
sceprent Engine compartment unknown leak. 1996 - 2004 SN95 Mustang -General/Talk- 2
V Mustang 2000 Unknown Part 1996 - 2004 SN95 Mustang -General/Talk- 2
jay07 Unknown Coolant Leak 2005 - 2009 Specific Tech 23
E Roc What Is This Part Called And Where Can I Buy Replacement ? 1996 - 2004 SN95 Mustang -General/Talk- 1
MYTURBO Unknown Wire 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
J Diagnosis Unknown 2005 - 2009 Specific Tech 11
M Unknown Button SN95 4.6L Mustang Tech 4
0 Unknown Fluid Leak...need help SN95 4.6L Mustang Tech 5
6 unknown bracket Classic Mustang Specific Tech 5
C Can anyone here run a VIN for me? Unknown miles on a car.... 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
S Unknown noise SN95 4.6L Mustang Tech 10
B Help, unknown Knock driving me crazy. SN95 4.6L Mustang Tech 21
R 2 unknown harness plugs... Fox 5.0 Mustang Tech 3
94302Stang Unknown prob anyone help please! 1994 - 1995 Specific Tech 44
coffmaad Unknown plug/wires Fox 5.0 Mustang Tech 0
Foxy2.3TC unknown noise help pls!! 2.3L (N/A & Turbo) Tech 6
warriorpluto tranny pan pic. unknown tranny Fox 5.0 Mustang Tech 21
superstroke17 Unknown sensor-tc 2.3L (N/A & Turbo) Tech 1
Pakrat What's a fair price for an unknown condition 351W? Classic Mustang Specific Tech 12
StinkinLincoln unknown parts 1994 - 1995 Specific Tech 3
R EVERYONE experiencing unknown overheating problems Please Read!! Check Ground Wires! 1994 - 1995 Specific Tech 5
T Unknown OBD Error Code 2005 - 2014 Specific V6 Tech 1
Tom95gt unknown plug in door 1994 - 1995 Specific Tech 9
S Unknown Rattle Noise 2005 - 2014 Specific V6 Tech 4
bad98rt Unknown part under hood?? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
bad98rt Unknown Part on 93 notch Fox 5.0 Mustang Tech 1
6 Unknown heads 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
S New Mustang! Help with the unknown needed. 2.3L (N/A & Turbo) Tech 2
JBushman73 04 GT Procharged vs. 01 Cobra (unknown mods) 1996 - 2004 SN95 Mustang -General/Talk- 9
glowstang93 Unknown idiot light SN95 V6 Mustang Tech 6
glowstang93 Unknown idiot light SN95 4.6L Mustang Tech 4
S UNKNOWN ENGINE or EXHAUST TAPPING SOUND? Fox 5.0 Mustang Tech 6
fawcett Need Help, Missaligned Engine, Trany, Driveshaft+Unknown Noise 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 5
TheRican Unknown Tapping Fox 5.0 Mustang Tech 3
aleborjas 2000 mustang unknown codes SN95 4.6L Mustang Tech 13
