1995 Mustang GT, stock except k&n air filter.
Well, after some wrench turning on my car, my idle speed is still out of whack. Here is a quick briefing on my problem.
Idle speed varies anywhere between 2000 - 2800 rpm's.
Before this problem, my idle speed was a little low (around 500 rpm's). So I removed the IAC valve, soaked it in carb cleaner, and put it back on. I then cleaned my k&n air filter. I put everything back on, allowed 3 hours for the oil to dry in the filter, and started the car. The 2800 idle rpm problem started then.
So, today I bought a brand new IAC valve w/ gasket. I installed it, and it changed nothing. I checked the voltage, and it read about 11 volts, which means the PCM is giving the correct signal (acceptable range is 10 - 12 volts).
Tomorrow I am going to remove the IAC, and have someone cycle the ignition on/off while I watch the new IAC valve to ensure it's working properly.
Assuming the new IAC is working, what could cause the problem? There are no vacuum leaks where the IAC & TPS meet the Throttle Body.
Could the TPS be screwing things up? I thought the IAC valve was the only thing that determines the idle speed. If anyone could point me to some technical data about the TPS and IAC valve, it would be appreciated.
BTW, I tried turning the screw on the TB and I could only increase the idle speed further (turning counter-clockwise). I turned it clockwise as much as possible (to decrease), but it won't go any more.
Anyone have any ideas?
BTW, which wires do I need to probe on the TPS to check it's voltage? What should I read when the throttle is closed? At WOT?
I am getting close to taking it to a frickin' mechanic. This is really irritating!
Thanks for the help!!!!
Scott
Scott
