Do you mean bigger brakes, or just better pads and rotors for the brakes you have?
GT and V6 both came with the single piston front caliper. If you move to the Cobra Caliper, Rotor, Pads on the front, then you will be looking to change the master Cylinder also but I think but am not sure if the Booster is the same on both.
So as you can see, Most things on the V6 and GT are the same. If you are going to change things. Go to the Cobra System. Means new EVERYTHING
So for the front, If I do the Cobra system, I would be able to use the existing front mounting brackets?
