Ok...So I am in the process of replacing the throwout bearing in my 94 GT, and when I pulled the driveshaft out of the tranny, it spilled a little oil out of it. I put some saran wrap and a rubber band around the end to prevent more spillage, but I figure I should add some to top it off again...or just change the oil completely. Where exactly do I drain and add oil?
On a side note, as long as I have the tranny pulled, I am going to upgrade the clutch. I think I am going to buy the FMS King Cobra clutch since it is only about $200 and includes the throwout bearing in the kit. I had also considered the Centerforce kit, but it is $350, plus you have to buy their TO bearing for another $35. I highly doubt I will ever be making more than 400rwhp with this car, so will the FMS clutch be just fine? Also, for people who have either clutch: How is the pedal pressure compared to stock? THe stock pedal pressure already is pretty heavy, so I'm worried that it will be even worse with an upgraded unit.
One more question:
While I'm at it, I think I'm going to install some headers. I'm pretty much set on BBK full length headers with the BBK catted H-pipe (just in case some anal retentive cop decides to look underneath my car). My questions is: Do the BBK headers have holes in them for the O2 sensos? Also, is there a hole for the EGR plumbing? And if so, does the stock EGR pipe fit to it correctly, or does it require some bending? (I ask because it is a hard pipe, not a flexible one.)
Thanks,
One more question:
Thanks,
