the main difference between hooking your vac advance between man and ported is if you have a ford or a chevy. the old bow ties idle like crap(huffing, dieing when put in gear, etc) at the 8-10 degree setting they like to idle best around 15-20(no joke) but setting the dist there with a small cam you just cant turn the damn things over when they get warm, so man vac for chebbys.
just for a little clarification on ported vacuum, ported vac source is a little slot starting just above the throttle plates when the plates are opened a little, the slot is now partially below the plates giving some vac, at about 1/6 throttle they are completely below the plates giving the same vac as would be on the manifold.
ported vac would give more part throttle torque at lower rpms. the reson it drops off at more throttle is that cylinder pressures increase and the mixture burns faster making ping at lower engine speeds so we need less timing at wot. idealy timeing would always be maxed out to the point before pre ignition at wot and tame at idle but that is very hard to do without the use an ecm and detonation sensor. so we back the mechanical curve down at lower speeds and throw in vac advance for part throttle
but as for us computer impared engine users, 3 reasons for not using ported vac.
1 you have a relatively stock chevy
2 you have a higher compression engine(9.5:1 or so and above) with a low stroke to rod ratio(302, 351c) alot of times this will create ping without retarding the hell out of the timing, or you can get an adjustable vac pod to limit the vac advance.
3you have a hefty cam(280 grind or above) this with me at cruising speed tends to hop skip misfire after total timing has been set to 38 degrees.
hope this answeres your question
