I recently put some lower control arms on my car and everything was working decent...I still had a slight vibration above 70mph but went away mostly at 75. I just changed the u-joints on the driveshaft everything is in right I put it in the same way it came out. It now vibrates very bad above 65mph. The output shaft of the transmission moves up and down and side to side almost a 1/8th of a inch. Does the output shaft suppose to have any movement at all....if not is there a bushing or bearing that I can replace without having to remove the transmission? Anyone ever have this problem or know How I can fix it?
