Voltage Spike - Both Low and High
Danman765432
471
Nutley, NJ
Ill start off by saying that it first happened two days ago when i turned onto my friends street. When going down the street I noticed my red battery light was on and my volt meter was at 18v's. I shut off the car and coasted down the road. When I got to his house I started it back up and everything was ok and the volt meter was reading where it normally does.
So the day after which was yesterday, I brought my battery and alternator to autozone and everything checked out fine.
Tonight when I was bringing my girlfriend home, as I was leaving I saw my lights get brighter and it was at 18v's, then it steadied out and then it went lower in volts to probably around 10 or so. Then it came back up and steadied out.
What does this sound like to you?, I wish it didnt pass at autozone so I could have just gotten a new one. To me it sounds like a voltage regulator or something of that sort. I also do have a spare alternator laying around so i might toss it on but then I still cant get a new one from autozone.
-Dan
  • Sponsors(?)
legalize420
1,541
South Florida
try the regulator from the spare. i recently had an alternator test good but still did not charge when i brought it home. after double checking everything on my end i knew it had to be something with the alternator. im not sure if they bypass the regulator during the test but i talked them into giving me another and everything has been good since then.
Danman765432
471
Nutley, NJ
now that I am thinking about it, when it stops snowing I am just going to toss on my 200 amp alternator and I have an old alternator sitting around that has a bad voltage regulator and Ill take that off and put it on the one that is currently on my car and then ill bring it back and have them replace it.
I checked for loose wires and grounds and couldnt find anything...I had my battery charged to full capacity yesterday. So i know it pretty much isnt those two things.
HISSIN50
SN Certified Technician
28
129
Another regulator vote/guess. It sounds like you've done one, but if you haven't, it takes about 30 seconds to swap them out.
Thread starter Similar threads Forum Replies Date
9 Voltage spike & ABS/Battery light on... 1994 - 1995 Specific Tech 2
squares98 Voltage Spike Issue SN95 4.6L Mustang Tech 3
jb89coupe TPS voltage spike - it's not the sensor Fox 5.0 Mustang Tech 4
YadiStang Low voltage at coil - after trying to start the motor? 1965 - 1973 Classic Mustangs -General/Talk- 1
B 95 mustang cooling fan voltage 1994 - 1995 Specific Tech 1
L Electrical Voltage on GEM high power fuse terminals with fuse removed. SN95 V6 Mustang Tech 0
R 04 Mustang GT Voltage/Electrical Issues 1996 - 2004 SN95 Mustang -General/Talk- 3
T Fuel Low voltage at pump harness plug. 2.3L (N/A & Turbo) Tech 9
J Electrical TPS voltage Fox 5.0 Mustang Tech 58
P Alternating pitch whine accompanies voltage problems Reply Subscribed SN95 V6 Mustang Tech 4
Jmed05GT Low voltage while idling and no battery light 2005 - 2009 Specific Tech 1
PonyGTrider Engine Uncertain MAF voltage Fox 5.0 Mustang Tech 28
Russ Cochran Low voltage at pin connector on alternator Mustang Sound & Shine All 1
D Getting codes 998 and 122. 2.3L (N/A & Turbo) Tech 1
D Where is the Eec Relay? 2.3L (N/A & Turbo) Tech 7
K Ignition coil input voltage. 1965 - 1973 Classic Mustangs -General/Talk- 1
D Surging idle 95 mustang gt 5.0 bolt ons 1994 - 1995 Specific Tech 12
E Low voltage at fuel pump fuse SN95 V6 Mustang Tech 4
Blucifer99 Does anyone kno the deadtimes and voltage offset for these injectors Digital Self-tuning Forum 0
9 94 gt low voltage at fuel pump 1994 - 1995 Specific Tech 0
Lunysgwen Electrical Pin 17 voltage with EEC removed and Key On/Engine Off. Fox 5.0 Mustang Tech 1
T 2004 GT - Computer Voltage Question SN95 4.6L Mustang Tech 13
90Hatchback Battery voltage slowly dropping Fox 5.0 Mustang Tech 18
Hudson N Voltage regulator/alternator problems Fox 5.0 Mustang Tech 2
T Electrical 87 map sensor voltage high Fox 5.0 Mustang Tech 12
Blucifer99 Electrical 92LX o2 sensor voltage question Fox 5.0 Mustang Tech 4
G Solenoid no voltage 2005 - 2014 S-197 Mustang -General/Talk- 0
R VOLTAGE HELP 1996 - 2004 SN95 Mustang -General/Talk- 5
B Electrical Pin 46 Voltage Fox 5.0 Mustang Tech 5
Stevenmverrill Iso, Maf Voltage=air Flow 2005 - 2014 S-197 Mustang -General/Talk- 0
MafiaMustang Low Voltage At Idle Fox 5.0 Mustang Tech 8
Dane Brahler Alternator Voltage? Fox 5.0 Mustang Tech 21
Trent B Engine Stall After New Battery 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 2
wmburns Reference Howto Perform Charging System Voltage Drop Test Resource Discussion Forum 1
H What Should The Voltage Be From The Ignition Trigger Wire To "i" On Solenoid? 1974 - 1978 Mustang II Talk & Tech 4
H 94 Gt, Starter Relay Clicks, No Voltage At Solenoid 1996 - 2004 SN95 Mustang -General/Talk- 2
H 84 Mustang With Odd Electrical Issue Fox 5.0 Mustang Tech 5
flashback87 3g Alt Voltage Regulator Sense Wire? Fox 5.0 Mustang Tech 6
J Weird Voltage Problem. SN95 V6 Mustang Tech 2
J No Voltage To Tps Intermittent No Start/run Fox 5.0 Mustang Tech 7
S Electrical Low Voltage In 87 Fox Fox 5.0 Mustang Tech 5
S Unexplained Voltage Drop SN95 4.6L Mustang Tech 1
D Electrical Eec Pin To Ground Measurements, E.g., Resistance, Voltage Fox 5.0 Mustang Tech 5
S 1967 Mustang Alternator Charging Problem 1965 - 1973 Classic Mustangs -General/Talk- 0
C Low Voltage Fox 5.0 Mustang Tech 4
grnhays Tps Voltage Question Fox 5.0 Mustang Tech 11
B Electrical Tps Troubles. Low Voltage At The Vref Or Org/wht Wire. Fox 5.0 Mustang Tech 26
Caydink1998 Please Help! Battery Problems..? The Welcome Wagon 3
echo7 Battery Voltage Seems Low To Me... 2015+ (S550) Mustang -General/Talk 7
A Iab /iac Possibly Not Getting Voltage? Fox 5.0 Mustang Tech 6
