my e-brake on my 90' mustang seems week. I try to pull it to drift around corners but it doesnt so anything. any ideas?
seijirou said:well you could always upgrade the rear to disc to get more grip, also you may need to adjust your ebrake. if you pull out the center section of your console and pull the ebrake up, you will see a threaded stud at the bottom of the ebrake with a threaded nut, tighten this nut down and it will tighten up your ebrake cable so that it will put more braking pressure to the rear brakes when you pull the lever up.
be sure not to tighten this down too much or it will cause your rear brakes to drag all the time.
sxystev0 said:my e-brake on my 90' mustang seems week. I try to pull it to drift around corners but it doesnt so anything. any ideas?
bgjohnson said:he meant a parking lot I'm sure, and you guys are aware that his year mustang has self adjusting brake pads right? and the way to automatically adjust them is back up and brake hard a couple times and it causes the little adjustment arm to push up the star adjustment wheel, the only reason there is a opening in the backing plate is for initial adjustment, if you do it wrong your car could pull to one side or you could mess up and heat crack your pads or drums
the huge 8 foot wing will help im sure.fordman54935 said:Did the thought ever cross your mind that the emergency brake doesn't work because you pull it up to try drifting around corners?
You are lacking in either brains or maturity.
Sell your Mustang and get a Honda if you want to do that crap.
