Hey folks, has anyone seen this before?
I went to do a trac-loc rebuild on my 1 wheel peeler and had the odoriforous experience of having the axle cover off and went to punch the crosspin out of the differential and thunk. It hits the 4.56 ring gear. The ring is too tall! I honestly have no idea how they got it back together in the first place but there is no way on this earth that the pinion shaft is coming out past those gears. I have a tracloc and a rear disc brake kit to install.
Do I grind off some of a ring gear tooth or grind off some of the pinion shaft or what else can be done? I SMACKED it with a deadblow mallet and it came halfway out but this is only cause it has a small flat part. It slid out as far as it can go but it wont go any further since it becomes round again and it wont help me to have it sticking into the back of the case.
Hey is gear oil supposed to be like thick cold molasses? I popped the cover off and was surprised that the fluid slowly rolled out instead of spilling out. Maybe skipping the friction modifier will put some friction back into those old tracloc clutches.
