world block bored to 4.125
complete forged scat rotating assmbely w/ flat tops and a 3.400 stroke should be around 10.1:1
Trick flow fast as cast heads with bowl blend
trick flow R intake not the boxed one
accufab 90mm TB
with a custom ground cam from Camshaft innovations
Duration at .006" 263.68 278.93
Duration at .020" 241.48 255.77
Duration at .050" 215.56 229.52
Duration at .200" 139.25 152.84
Lobe Lift .35252" .35239"
Rocker Ratio 1.60 1.60
Gross Lift .564" .564"
Lash HOT HYD HYD
Net Lift .564" .564"
Designed Lobe Centerline 112.15 ATDC 115.88 BTDC
Open at .050" -4.37 BTDC 50.64 BBDC
Close at .050" 39.93 ABDC -1.12 ATDC
Lift at Top Dead Center -> .0393" @ 112.15 In.Center .0467" @ 115.88 Ex.Center
let me know what you think
accufab 90mm TB
Lash HOT HYD HYD
