What does this cold start engine ticking sound like to you?
  • Sponsors(?)
midnightdriver
443
Northern California
That's not an option. Any input on what it sounds like?
Why is that not an option?
Well if I had to take a wild guess I would say it has to do with your oil systems. Sounds like cam tap/valve tap/lifter tap or something with the timing chains such as a tensioner that is stuck or corroded in a way that it takes longer to build up oil pressure to make it function correctly.
That is taking a wild guess. Until you figure it out, I would personally not drive it too far.
Have you check the oil level lately?
trinity_gt
3,125
80
99
Canada
Get an oil pressure gauge -- a proper one, not the dummy "gauge" on the cluster -- and check it while making this noise. If the oil pressure is okay you might have a timing chain tensioner issue. If the pressure is low you might have a pickup problem, a clearance issue in the engine (e.g. main or rod bearing with excessive clearance) or perhaps a problem in the oil pump itself (e.g. sticking bypass.)
Try to isolate the noise in the engine: front, rear? Top, bottom? Left, right?
When the noise stops, does it just sort of fade away or abruptly stop?
Once it's stopped, do you hear any other noises from the engine at any time (accel, coast, overrun, idle etc)?
When the engine was rebuilt, what components were used? Were forged pistons used? They can be noisy on cold-starts though this noise doesn't really sound like piston slap...
Has it always done this since you've had it or is it a new development?
trombonedemon
Well-Known Member
Jun 25, 2009
1,963
39
59
U.S.A, U.S.A., U.S.A.!
Well, My engine is freshly rebuilt/overhauled, the builder put 10W-30 in the engine, engine sounds fine, I changed the oil to 5 weight, now I have lots valve train noise. The reccomended putting 10 weight back and a quart of Lucas oil.
BillyT903
Banned
Jan 10, 2004
377
San Francisco, CA
It fades away slowly after about 1 - 2 minutes. Also gets less noticeable as the idle slows down.
Only about two times after an hour of hard highway driving it made a slight ticking just after exiting the freeway at the stop light that went away within seconds. No other noises since and haven't heard that in a while.
I thought the motor sounded kinda noisy when cold from day one, and it could have made this noise all along but it seems to have become more noticeable. I also took it for its first oil change 3 weeks ago and so it may have gotten louder since then. I took it to a mechanic who let it sit for a couple hours but he never heard the noise. It doesn't jump out at you and I had to take like 6 videos before I captured it this well. It also goes away too fast to drive it even a few blocks anywhere and have anyone hear it.
nancygrl
257
If it was an old school motor (OHV) I would say it sounds like a collapsed lifter because it goes away once the engine warms up, but we don't have lifters per-se w/pushrods etc. Similar engine ticking seems to be a common issue with f-150's with the 4.6 and 5.4 motors. From what I've found searching online, if it's in the top end it maybe a lash adjuster.
BillyT903
Banned
Jan 10, 2004
377
San Francisco, CA
I suppose this could be doing some damage when it happens, right?
Does it make a difference whether I just let it warm up or start driving right away?
And what if heavier weight oil makes it go away?
Thread starter Similar threads Forum Replies Date
J Does IAC operate on a COLD start? Fox 5.0 Mustang Tech 8
J Does IAC operate on a COLD start? Fox 5.0 Mustang Tech 1
5point0stang88 Why Does My Car Not Idle Higher When Cold? Fox 5.0 Mustang Tech 11
B Cold air Kit with Throttle body space does not fit 2005 - 2009 Specific Tech 0
87_GT why does my friends car die when cold? (not a mustang) 1994 - 1995 Specific Tech 6
thedaddystang does cold weather effect feul pump Fox 5.0 Mustang Tech 1
OrangeMustangGt Why does my car run so damn cold? 1994 - 1995 Specific Tech 3
9 Does cold air pipe void waranty SN95 4.6L Mustang Tech 5
Black95GTS Does my stang run too cold?? 1994 - 1995 Specific Tech 20
silverlx50 Engine Does anyone have a picture of the O2 sensor harness orange ground wire? Fox 5.0 Mustang Tech 3
R 1995 Mustang power window does not work. 1996 - 2004 SN95 Mustang -General/Talk- 0
79pace 82GT Does not Crank the Starter with the Key 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 4
S vehicle shut of and does not want to start up again 2005 - 2009 Specific Tech 0
F Electrical Does EFI computer case need to grounded? Fox 5.0 Mustang Tech 22
Habu135 Fox : How Much Power Does a Stock 1993 Cobra Make? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
S Does Having a dead battery make the PCM fail? 2005 - 2014 S-197 Mustang -General/Talk- 0
M Brakes Does anyone know specific casting numbers on 1989 GT O.E. Calipers? Fox 5.0 Mustang Tech 11
G One coilpack not getting spark but does have power at wire SN95 4.6L Mustang Tech 3
C Does a 2015 Mustang have a radio code? 2015+ Specific Tech 0
J Does anyone know where this wire goes? Other Auto Tech 28
kiddiccarus Does anyone customize the interior of the 94-95? I am running into brick walls 1996 - 2004 SN95 Mustang -General/Talk- 0
T Need good/affordable cooling fan for Mach 1 that does not vibrate too much 1996 - 2004 SN95 Mustang -General/Talk- 3
S Where does this negative cable go??? 2005 - 2009 Specific Tech 3
9 What does the coil pack Capacitor do ? 1996 - 2004 SN95 Mustang -General/Talk- 3
Z Newbie question, Backup lights on 65. Does 12v for lights go thru neutral switch? 1965 - 1973 Classic Mustangs -General/Talk- 1
C Does she have a nice rear end or what? 1965 - 1973 Classic Mustangs -General/Talk- 10
ndfox92 Fox does anyone have a victor efi intake for a 351w they want to part with? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 0
MrPerfect2 What does the idle sound like if timing is 14 vs 12 degrees 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 18
J 94 GT Convertible. What does this harness connect to? 1994 - 1995 Specific Tech 0
J Paint and Body Does my floorpan need replacing? Fox 5.0 Mustang Tech 8
A Does it make sence ? 2005 - 2014 S-197 Mustang -General/Talk- 1
90sickfox Does any one else wish the 18 amd 19 fog lights were lower ??? 2015+ (S550) Mustang -General/Talk 0
M Does anyone know what the hole to the left of the oil pressure sender is for?? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
J Does Ford Performance make 3.73 gear for v6 mustangs? 2005 - 2014 S-197 Mustang -General/Talk- 8
MrPerfect2 Engine 1991 - What does a normal idle suppose to sound like on OEM 5.0 ? Fox 5.0 Mustang Tech 7
horse sence Shaker assembly ,what year does it fit? 2005 - 2014 S-197 Mustang -General/Talk- 3
79 Fox Fox Burning oil... Does my theory make sense? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 9
79 Fox Fox Does this make sense? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 6
D Engine Does this look like TDC? (SOLVED) Fox 5.0 Mustang Tech 2
Blucifer99 Does anyone kno the deadtimes and voltage offset for these injectors Digital Self-tuning Forum 0
K Does Orange Dexcool Turn Red/Pinkish? S550 Mustang 2015+ (S550) Mustang -General/Talk 0
billison Does anyone else have one of these. 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 15
BlakeusMaximus Where does antenna wire disconnect? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 1
B Does the coolant tank on this 4l v6 look ok? 2005 - 2014 S-197 Mustang -General/Talk- 0
DrSmart 95 GT Conv. Does the Keyless Entry Module feed power to the Speedometer? 1994 - 1995 Specific Tech 0
B 2001 gt Does it have a tune? SN95 4.6L Mustang Tech 1
R Engine Cammed 1988 Mustang LX - Does this sound right? Fox 5.0 Mustang Tech 11
Hudson N Anyone know what this does? 1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- 7
M Interior and Upholstery What does this button do? 2015+ (S550) Mustang -General/Talk 2
